LG Y-SUS board, IGBT GT30F133 equivalent / replacement urgently needed, please !!!
  • jczarniak
    • Oct 2015
    • 179
    Anyone knows any equivalent / replacement which I can buy in RS Components, please?
    IGBT MOSFET: GT30F133
    Thank you.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG Y-SUS board, IGBT GT30F133 equivalent / replacement urgently needed, please !!
    Ebay offer them
    http://www.ebay.co.uk/itm/transistor...-/401141628526
    • jczarniak
      • Oct 2015
      • 179
      Originally posted by dick_barton
      Thank you.
      Any other idea where from I can get them (or equivalent) today?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        give wiltsgrove in birmingham a ring i used too use them a lot when i lived in cov digbeth area of birmingham so easy to get to 0121 772 2733 not the cheapest of shops but hey if you need it today.
        • Alekov_31
          IGBT replacement
          by Alekov_31
          Hi guys, I'm repairing a welding machine which has 12 blown IGBTs in the power supply. The blown IGBTs are no longer available and has a replacement part that has lower power dissipation. The original IGBT is SGP30N60HS (250w) and the replacement is IGP30N60H3 (187w). Is there a problem to change with the replacement part or I have to search with higher power dissapation
          11-23-2023, 02:36 AM
        • PlasMatt
          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
          by PlasMatt
          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
          09-20-2025, 06:50 PM
        • issam19dz
          B450 AORUS M Looking for Equivalent Replacement for MOSFET EMF30N02J?
          by issam19dz
          I'm hoping to get some help finding a suitable replacement for the MOSFET EMF30N02J. I'm currently using this component in B450 AORUS M motherboard
          Any information or advice would be greatly appreciated!
          Thanks, [Issam Seb]
          05-01-2024, 04:26 AM
        • DXseekerMO
          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
          by DXseekerMO
          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
          If anyone has a link to where I can buy what I need that would be even better.
          These are the caps that have burst:
          Board location: C8BV, C26BV, C43BV
          Brand: United Chemi Con
          Series: KZG
          Size: 10mm dia X 25mm height
          Impedance: (ohms max/20c, 100kHz) .012
          Ripple: 2800...
          02-04-2022, 04:48 PM
        • mikkele86
          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
          by mikkele86
          hello.
          I have two power amplifiers, both having their IGBT blown on the PSU.
          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
          So I though i missed a capacitor or diode. I removed...
          01-06-2024, 06:45 AM
