IGBT replacement
  • Alekov_31
    • Aug 2021
    • 6
    IGBT replacement
    Hi guys, I'm repairing a welding machine which has 12 blown IGBTs in the power supply. The blown IGBTs are no longer available and has a replacement part that has lower power dissipation. The original IGBT is SGP30N60HS (250w) and the replacement is IGP30N60H3 (187w). Is there a problem to change with the replacement part or I have to search with higher power dissapation
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    A compatible part is APT30GS60BRDLG, but only one problem. Package size is TO-247.​
    • petehall347
      • Jan 2015
      • 4448
      dont go lower they are probably on the edge as it is . best figure out why they blew first . then do the upgrades
      • TURSTY
        Replacement IGBT's for LG TV reading weird
        by TURSTY
        Hi guys,
        I have a LG Plasma that went bang one night.
        Long story short, I took it to a "professional" shop to repair the YSUS board that was shorted and they did a half ass job.
        I'm a long way down the path of teaching myself component level repair, but not 100% confident in everything yet, hence what might be a basic question.
        The repair shop replaced 3 transistors on one of the two heat sinks and fixed one short, but the second set of transistors on the second sink still had a short.
        So I removed this sink...
        08-01-2023, 07:38 PM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        Today, 12:34 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
