42PD8600 No Picture-17MB15E-5 Ideas ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    I could pick this Tv up for free, its a FHP Plasma which switches on and the panel primes but there is no video being processed by the mainboard which is a Vestel shit. Just wondering if any one has any ideas before I collect it.
    The susboards are working as the panel comes up full black, Im guessing the control board is fine and its the Vestel part at fault as usual lol. 17MB15 no Lvds fault maybe ? Any ideas are appreciated and I will decide if I go get this Tv. Cheers.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 42PD8600 No Picture-17MB15E-5 Ideas ?
    Guess I will go get it and diagnose it then, will be collecting tomoz and let you know what I find
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      well you cant turn down a free set and if you fix it some profit for you.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        It's free.....take it....I would.....I'm with you...Main board issue...as you pre-diagnosed.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yeah I suppose even if I sell it for £10 thats a profit chaps. This is also a real FHP PDP and
          Sus boards in this set too have not seen one of them since I started fixing Tv's 2 years ago.
          I will arrange a lift tomoz and let you know what I find probably something stupid being a Vestel Mb. Shame they did that, use a good Pdp and Psu but Vestel shite mainboard lol guess it was so much cheaper that way
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Did you pick this up reece?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              I did yes, I might be opening it later today as got lots of other repairs to do buddy
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Mainboard was failed decided not worth fixing/debugging it, chucked away.
                • Rictech
                  Panasonic SA-MAX770PU SMPSU board fault....
                  by Rictech
                  Hello everyone. 😀
                  As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                  Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                  Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                  This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                  There are no devices that have exploded or otherwise show signs...
                  08-26-2024, 01:05 AM
                • France_53
                  Vestel tv, how to flip the image?
                  by France_53
                  Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                  05-12-2024, 05:22 AM
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  ESR meter came to the rescue again today with a PLC I/O card fault
                  I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                  I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                  One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                  12-18-2023, 08:17 PM
                • jimbofz
                  horizontal "smear" panel fault?vestel alba lcd 40781f
                  by jimbofz
                  Hi this early vestel with inverter and ccfl backlight came in with no backlight and it was the usual suspects on the inverter board ,4 fets ao4616 ,i ordered a kit and repaired inverter .
                  i now have this smear approx 8 inch from bottom on left hand side
                  its about half inch wide it stops approx 3/4 across .it doesnt change with pic content
                  i have examined panel closely for any damage ,
                  none of the tabs are running hot .
                  would value your opinions if it is the panel.
                  ive had many plasma and lcd tvs with horizontal lines,
                  but they usually go right...
                  03-31-2021, 09:55 AM
