Replacement mosfet for SBR10U100CT
  • speedypro
    • Feb 2013
    • 561
    As in title, is there a replacement? ebay.co.uk shows nothing. Anything locally, UK?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8214
    Re: Replacement mosfet for SBR10U100CT
    It's not a MOSFET. The SBR10u100 is a fast switching diode on some super barrier tech that has a rating of 100V 10A. There are tons yof other devices you can replace it with. Matter effect Digikey has over 300 of those in stock.
    • speedypro
      • Feb 2013
      • 561
      Thanks for that. Do they come under different names?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You need to compare the specifications. Voltage and current ratings and also switching speeds.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8214
          Look for another 100V, 10A fast switching, Schottky diode array. The PSU will work to 99% the same. You can't use any "standard diodes" they are too slow.
          The super barrier is just a more "efficient" diode. Up to you what you change it to.
          As I already said, Digikey has the SBR10U100 in stock. Just go to their website, put SBR10U100 in their search and it will lead you right to it.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Stps20s100cfp will work but 20amp rated.
            • speedypro
              • Feb 2013
              • 561
              Thanks, all.
              • DoOm86
                Dual mosfet replacement help
                by DoOm86
                Hello.
                I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                It seems to be a 30V dual asymmetric N-channel AlphaMos.
                Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                And here is where I need help!
                It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                Thanks!...
                10-31-2023, 12:03 PM
              • Rauni
                Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                by Rauni
                Hello, this is my first post on this forum, and my first attempted to repair a TV.
                My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                Read also that we should test what happens if we...
                10-01-2023, 12:06 AM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • String2016
                SMD MOSFET REPLACEMENT
                by String2016
                Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                01-23-2025, 06:35 PM
              • String2016
                by String2016
                i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                12-15-2024, 05:31 AM
