Lg 60pn5300 sound no picture.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I can buy this Tv today for $80.
    Does it sound like ysus or zsus fault?
    It has sound and no picture.
    Probably zsus.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 60pn5300 sound no picture.
    Diagnose it.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      I have to go buy it first. I was trying to determine if I should spend the money lol.
      User said he was watching it last night and the picture went out.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        We cant predict the issue mate, so many common issues with these shite LG Plasmas could be anything. Use your PDP and DMM skills and let us know I would buy it good price tbh
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          Vs reads correctly at 203v, Va reads correctly at 55v, I also have 5v wherever asked for.
          On the zsus there is a pin that reads 15v, it is on the connector that goes from the zsus to the ysus. It only reads about 5 volts.
          Before I take boards off to inspect the back of them, I'll wait to see if you want me to check anything else.
          A working zsus is $14 on eBay.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Ordered ysus and zsus from eBay. Will post the results.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Tested Vsc ? Tested V drive ? Zbias ? Even ran test patterns ?
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                I posted up above what I tested.
                I disconnected the white cable that goes from the logic board to the main board.
                Jumped the ext auto gen and nothing on screen.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  Not sure what this is. It's like a little separate piec that hooks up to the zsus.
                  Shopjimmy doesn't have it listed.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Sounds like the Susboards then, but you should test what voltages they gove at set places too.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      I did. I checked them all, the only place I'd didn't read as labeled was the 5v where it should have been 15.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        VZB fluctuates between 70v and 80v.
                        VSC between 0 and 5v.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Ysus or buffers is the fault then. Remove the buffers and recheck Vsc.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            Pin #5 on connector P174 of the zsus is labeled at 15V. It only reads 5V.
                            It's the the connector that feeds the ysus.
                            The ysus isn't directly connected to the psu. It is only connected to the ysus.
                            Wouldn't that difference in voltage indicate some kind of problem.
                            It measures 5v with the ysus disconnected from the zsus, so the ysus can't be bringing it down.
                            I really have to disconnect the buffers from the ribbons. If it's anything like the panasonics, I don't want to have to line them back up. Lol
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              No remove the buffers from the Ysus and test Vsc matey.
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                With the buffers removed VSC reads 0 but pin #5 on connector p174 reads 17.7v.
                                Picture from shopjimmy.com
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  With the upper buffer connected connected and lower disconnected the #5 pin reads 17v and VSC reads 5v.
                                  With just the lower buffer connected #5 pin reads 5v and VSC jumbos from 0 to 5v.
                                  I take it the lower buffer is bad?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Check the buffer Ics for short now, do you know how to do this ? Also back to my point dont just buy parts because they can cause an issue find the issue first thats why BCN is here !
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      I know how to check the buffers on Panasonic. This is the first lg I've gotten that didn't have a bad picture and a bad zsus. So I knew what it was right away.
                                      Checking it the same way as I check the Panasonic buffers, the lower IC on the lower buffer is shorted.
                                      I'm not replacing the IC. Not when the buffer is $20. Lol
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Replace the buffer then, but cancel the Susboards you need to now check them for short circuits on the transistors mounted on heatsinks and surface mounted too.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
