Funky colors on a Sanyo DP50710
  • hardfahrer
    • Jun 2015
    • 9
    I recently put a used SC board in a Sanyo DP50710 and got it to turn on where it would not previously. I pulled up two sample pictures that the set has factory installed and the pictures were not sharp and the color was not right. (See attached pics) I am very novice with this and could use any help in determining what the problem might be and how to go about fixing it. Thanks in advance.
  • mmartell
    • Oct 2013
    • 3189
    Re: Funky colors on a Sanyo DP50710
    Not sure if that's still a ysus fault or other. But lookup how to run the internal test patterns to rule out the main board being the cause.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have you measured all the voltages as given on the PDP panel and do they match.
      • bohaboha
        Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
        by bohaboha
        Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
        anyhow i couldn't t read anything else
        the backlight is on strong and the screen does not get dark or very dark but no pictures
        the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
        01-02-2025, 08:04 PM
      • silikon77
        Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
        by silikon77
        Hi!
        Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
        Found some advices watching youtube nad came up with this:
        It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
        I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
        See attached picture.
        I tried a few combinations to block individual clock...
        01-02-2025, 02:26 PM
      • valvashon
        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
        by valvashon
        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
        11-24-2024, 12:08 PM
      • cj_reha
        Mystery 80s Sanyo cap - perhaps polymer?
        by cj_reha
        Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
        01-06-2023, 09:24 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
