Less temp degrees on caps?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i repaired my Hd Nfusion Satellite Receiver power Supply by replacing a few Caps,i used a couple 1000uf very good used caps that i had in my scrap, but i used 85degrees instead of 105 degrees,but i compensated by building a small 5 v fan on top of all the caps after opening a hole on the case,my question is? will this be enough to compensate for the less degrees temp of the caps
    Re: Less temp degrees on caps?
    The old cap low ESR type? Switching power supply?
    • Diah
      • Feb 2013
      • 6558
      not too much Temp deferent, if the 1000uf 25-50 volts are. with fan good idea but it would be better if the fan pull air from the box to out side
      • ivtec
        • Dec 2008
        • 1967
        Thanks the receiver already has a small fan in the back.You think i should reverse the fan?
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
