Samsung LNT4053H BL ISSUR
    Re: Samsung LNT4053H BL ISSUR
    AC VOLTS (45 Hz - 500 Hz)
    Ranges: 400mV, 4V, 40V, 400V, 750V ac
    Resolution: 100 µV
    Accuracy:
    ±(1.5 % of reading + 4 digits)
    ±(2.0 % of reading + 4 digits) 200Hz to 500Hz on 4V range
    Peak hold accuracy:
    ±(3.0 % + 60 digits) on 40V to 750V ranges
    400 mV, 4V ranges unspecified
    Input impedance: 10 M
    Overload protection:
    400mV Range:1000 V dc / 750 V ac rms (15 seconds)
    Other Ranges: 1000 V dc / 750 V ac rms
    No wonder it shows low reading, you are not reading the meter spec correctly.
    https://cdn.badcaps-static.com/pdfs/...403e88595d.pdf
    • jkb242
      • Mar 2012
      • 175
      You are correct my friend. I was thinking, presuming actually, that the frequency response for AC VOLTS was the same as the frequency measurement spec. Thanks for reminding me they are not. Good catch!!
        09-07-2024, 05:50 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
