lg 60pb660v plasma tv
  • thuss
    • Jul 2012
    • 321
    Re: lg 60pb660v plasma tv
    when I disconnect the tcon from the main board and reconnect all the connections the main board does not turn the psu permanently on. I think its the main board as there is no red optical(?) light on the main board.
    But as you said there maybe two faults.
    I dont think its the buffers/y sus or x sus as there are voltages on the test points.
    • Hamie
      • Apr 2014
      • 1383
      I still think you have a problem with y-sus and buffers.
      Can you take a photo of them.
      • Hamie
        • Apr 2014
        • 1383
        Found a pic.
        On this connected please post what the vsc voltage is when the screen flashes and also when it's off.
        • thuss
          • Jul 2012
          • 321
          the vsc voltage (on both pins) when screen is on for 2 seconds is 53v.
          then the screen goes blank the voltage continues up to and stays at 251v.(Should vsc be between 187 and 135? on the white sticker it states -187/NA/NA/135)
          the above values are when main board is not connected to the psu. But even when main board is connected the above values are the same and just keep rebooting as the tv clicks on and off.
          • Hamie
            • Apr 2014
            • 1383
            No it should be around 150v.
            OK can you post the voltage with the buffers disconnected.
            Also can you upload a picture of the top buffer.
            • thuss
              • Jul 2012
              • 321
              #26
              Yes will do- but do you mind if I ask why you want a picture of the top buffer is it for test points? I didnt see any burnt chips and I tried to do the test with the multimeter as per the 50pg3oo buffers but they seem fine.
              Without the buffers connected there is no voltage on pins 3 and 4 vsc but on the connector block below the vsc is still 259v
              • maxvalutech
                • 804
                • australia
                #27
                I tend towards Hamie judgement re y-sus followed by control board second choice. Of course the first thing is to get the set to stay on which is why suggested check with control board off from main. The control can't get voltage from power board as far as I can see from pics. Isolation testing does point to a main board problem and delay in switch off maybe a component warmup time while the continuous start up loop means that part of circuit is ok?? The reservation I have is if the x and y plus buffers any not connected does that initiate a shut down!
                • thuss
                  • Jul 2012
                  • 321
                  #28
                  Thanks for the help- I'm also leaning towards a y sus fault. Your right the control board once disconnected from main can only get power from Y sus.
                  - I'm not sure.
                  On the 50pqs and 50pgs one buffer can be disconnected and it will show you half a screen and wont switch off.
                  • maxvalutech
                    • 804
                    • australia
                    #29
                    Reading back to voltages you took I now note Vs 236v which if right is way too high and should be within 0.5v of recommended setting - overvoltage shutdown is likely at this level.
                    • thuss
                      • Jul 2012
                      • 321
                      #30
                      I found a couple of shorted "mosfets" on the ysus -Can anyone advises me on what their equivalents could be
                      AUK C3C16 SMK0825- Ive been to rs and several other electrical retailers without success.
                      • thuss
                        • Jul 2012
                        • 321
                        #31
                        I replaced the AUK C3C16 SMK0825 with 51n25.
                        The tv came on. However the vy voltage is still 181 even after I have turned it down with the adjuster. Allthe other voltages are ok.
                        So I assume I need to swap out another component on the Y sus board in order to get the vy down to around 150,
                        There are some pixels that slowly disappear ( i have reseated the ribbons between main board and tcon) also starnge is that it retains the tv menu on the left hand side of the screen - I suppose I should run the auto exgen gen?
                        • sordids999
                          • May 2013
                          • 2161
                          #32
                          Got one of these tvs found to be a faulty ysus but upon testing the psu I jumped 5.2v to Rlon but VS is measuring 316v and VA is measuring 68 volts Any ideas?
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            #33
                            It may read 316V, but is that with a load or with no load? Use 2-120Vac 100W household incandescent bulbs in series as a load and then re-measure.
                            • sordids999
                              • May 2013
                              • 2161
                              #34
                              That's with everything disconnected just psu jumped
                              I'll try the bulbs as well
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                #35
                                Yes. With everything disconnected from the PSU and using the Test bulb connected in place of the Y-SUS Bd. Your PSU is working properly, BTW. What fault are you getting??
                                • sordids999
                                  • May 2013
                                  • 2161
                                  #36
                                  Originally the fault was clicking from the psu found 3 shorted igbt on the ysus board and top buffer was shorted
                                  So further testing wanted to see if psu was ok so was confused why the voltage was so high on the VS and VA
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    #37
                                    Are you going to repair the Y-SUS Bd or are you looking for a replacement? Your PSU is good.
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      #38
                                      Well replacement ysus difficult to find unless you want to pay silly money so I'll look at repairing this ysus
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        #39
                                        Nice. Let's di this then.
                                        • thuss
                                          • Jul 2012
                                          • 321
                                          #40
                                          Soz about late reply- it was a couple of large resistors next to the mosfets (theres two of them) that were shorted
