Questions about Plasma voltages (PN60E530A3FXZA)
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi!
    I am working on a Samsung PN60E530A3FXZA and had some questions. The power supply looked pretty bad. There where heavy burn marks on the two thermistors and all the traces on the cold side from the larger transformer. For the larger transformer, there was discoluration on some of the traces for the hot side as well.
    I have seen other SMPS's for this panel that looked similar and replacing the thermistors did not fix the issue. The thermistors readed short circuit.
    Anyway, replacing the SMPS wasn't too expensive and I did along with the Y-Sustain board, which had bubbling on the board there in one spot.
    This brought life back into the plasma. I adjusted the various voltages, and these are what they are supposed to be, what they where and what I adjusted them to:
    Code:
    VScan: -194VDC, was -204.6VDC, adjusted to -194.0VDC
    Vs: 211VDC, was 208.7VDC, adjusted to 211.0VDC
    Va: 57VDC, was 56.7VDC, adjusted to 57.0VDC
    Ve: 98VDC, was 94.6VDC, adjusted to 97.9VDC
    I only have a couple questions here. I have only repaired one other plasma and that turned out to be a guessing game mostly at what board was causing what problems. I have tried to learn much more about plasmas since I received this one to repair.
    I want some clarification on what effects these voltages have on a Plasma Display Panel. I have searched the net, and so far, the best explanation I could find comes from Tom66, here at BadCaps.net
    The Va is determined by the panel technology including the spacing between the address and sustain electrodes and is typically fixed for any given panel technology. Excessively high Va can damage the plasma panel TCPs rendering the panel dead. The Ve is also determined by the panel gas pressure and is much more variable, it determines the erase/initialise bias energy for the common electrode side of the panel.
    It is my understanding,
    Va means Voltage Address for the X-Sustain and is for the address boards, is that correct? Incorrect voltage could mess up the picture on the panel, because the addresses are wrong, is that correct?
    Ve is Voltage Erase and is what "erases" the cell(s). So, if Ve was not correct, we could receive Image Retention. Is that correct?
    VScan = Vertical Scan (?) and has something to do with Y-Sustain. I am not exactly sure if I measured this correctly, because I see some places on the net says it should be measured across a resistor or capacitor because it's floating.
    VS = Voltage Sustain and powers up the Y-Sustain (?)
    I believe I was supposed to let the TV "warm-up" powered on for about 15-20 mins before adjusting the various voltages, and I did not do that. Now there is image retention on the panel. It goes away real quick if the white bars display on the screen. However, I feel they shouldn't stay like they do, and I'm going to have to remove the cover to adjust them again. I just wanted a better understanding of what the voltages did, and what the symptoms would be if they were off.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Capacitorial
    Powersupply has all the voltages - Monitor still no power
    by Capacitorial
    Hello guys,
    I have a Philips 240B7QPJEB. The monitor seems completely dead.
    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
    The weird thing is, that the Power LED is powered over the TCON board.
    On The TCON...
    12-28-2024, 02:12 PM
  • gjgib
    Help reading schematic voltages input/output
    by gjgib
    Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
    I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
    I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
    I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
    05-06-2024, 08:11 PM
  • RossMoodley1967
    HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
    by RossMoodley1967
    Hello
    Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
    Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
    03-01-2024, 06:07 AM
  • karlp028
    MSI Z390-A PRO missing VCORE voltages
    by karlp028
    I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
    06-23-2025, 01:25 AM
  • lol999
    Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
    by lol999
    Motherboard after starting show Q code 00.
    No shorts on any rail ( at last I can't finde any)
    All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
    Nothing get hot, PSU starting, all lights came ON....
    One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
    After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
    This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
    01-21-2024, 02:25 PM
