Prevent tab bonding issue?
  • Vinter
    • Aug 2016
    • Sweden
    Hello!
    Thank you for a great forum. I'm no expert by no means, just trying to learn.
    I've read some about the tab bonding issue that affect almost all manufacturers(?), maybe Samsung is over-represented?
    From what I can understand, it looses connectivity when overheated. Would added cooling prevent the issue?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Prevent tab bonding issue?
    I use a small dab of thermal paste on the Ic on the driver help it transfer heat to the chassis better.
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
    • elmark
      HP 15-cw1002ua strange keyboard issue
      by elmark
      HP Pavilion 15-CW1002UA
      S/N 5CD0251CBC
      P/N 7KE54EA
      Hello guys!
      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
      It powers on OK and has no other issues except the following:
      • CAPS LOCK does not work at all
      • Fn button toggles Flight Mode
      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
      • (with SHIFT pressed: 't%' and 'y^' respectively)
      I initially thought it was a keyboard malfunction (internal short, etc.),
      but when I press and hold...
      06-27-2025, 01:10 AM
