Re: Sharp LC-60SQ15U TV DPS-167CP - No power
If all components off of pin5 are good. May have bad ic.
Check pin 5 diode, resistor and cap.Leave a comment:
CAP c2 (C7907) i change but nothing changedLeave a comment:
between 3rd and 8th leg 300V9.1 Startup Operation
Figure 9-1 shows the circuit around IC. Figure 9-2
shows the start up operation.
The IC incorporates the startup circuit. The circuit is
connected to D/ST pin. When D/ST pin voltage reaches
to Startup Circuit Operation Voltage VST(ON) = 38 V, the
startup circuit starts operation.
During the startup process, the constant current,
ISTARTUP = − 2.5 mA, charges C2 at VCC pin. When
VCC pin voltage increases to VCC(ON) = 15.3 V, the
control circuit starts operationLeave a comment:
The voltage isn't high enough, just like you said here, the question is why, I can't figure it out but one of the pros knows I bet.Hello, please help me i have same problem on my Sharp Aquos 60LC635E No 5V power, tv dead . Blown R7900 and short D7950 . I changed it, than blown R7900 again . D7950 ok. I change IC7903 and cap on 5 leg 50V 47u and R7900 never blown again but 5V not( I do not know what to do . On big two cap 315V, on 5 leg IC7903 9V this very low for start A6069H . Datasheet say min 13V.
Please Help me. board power supply dps-162KP B RUNTKA932WJQZLeave a comment:
Attached Filesif you find these attachements useful please consider making a small donation to the site
make sure the resistors are the correct value and not open.Leave a comment:
I see, ok check c7906, r7909, r7919, d7904.Leave a comment:
no c7901 leg 8 .
Here is a very similar sheme
looks like it comes from c7901.Leave a comment:
Where should the voltage come from on the 5th leg A6069H?Leave a comment:
I check, they seem to be ok
what do you mean? A6069H defective? was my marriage sold?Leave a comment:
wonder if you received faulty IC7903 or if it has gotten damaged.Leave a comment:
maybe check c7901, c7907, c7818, d7805.Last edited by nomoresonys; 05-18-2022, 03:50 PM.Leave a comment:
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
