Re: Sharp LC-60SQ15U TV DPS-167CP - No power
Remove this supervisor IC7902, it sometimes brings problems with starting (the power supply works without it).
finally i saw now he post photos on his PCB.. i were wondering how other write parts No. and there was different model threats..
any way.. you don't have 5 V STB and PFC remain not active..
how are you testing. i cant find you wrote about.. where are the signal we are going to let PFC go high ?? this is not only Hot area work.. its cold area too.. beside i can see your soldering work the most worst i can see.. each part you took it out. you need to recheck the green line print chart 1000000000% you did break the lineLeave a comment:
PC7904 is used to turn on Q7902 to supply vcc_on so it can be left out of circuit for now.
If you also remove pc7903 and D7908, pin 4 of ic7903 should be about 7volts, If it does not come up, try isolating just pin4 from the circuit trace, this will eliminate any other component on that line as well.Leave a comment:
PC7903, PC7904 i desordered for check . PC7904 need soldered back? Disconnect D7908 and power on board for check 3,4 pin on ic7903 ?Leave a comment:
2.2 ohm red red gold gold
Attached Filesif you find these attachements useful please consider making a small donation to the site
on my T7901 1,4 - 0,5ohm, 2,3 - 3 ohm , 5,7 - 0,2 ohmLeave a comment:
Yes, check pins 1 & 4
The vcc voltage is initially supplied by the ic's internal startup cell which is bout 9volts, that part of the ic is working. When the power is first applied the internal mosfet should pulse the primary of T7901, this will induce voltage in the secondary winding and also the feedback winding, This will charge C7907 above 15 volts and the ic will stay operating, However the secondary voltage (5V) from D7950 must be regulated, so the optocoupler is used to control this voltage. The fact this feedback voltage is 40mV it is shutting down the ic.Leave a comment:
So which pin on T7901transformer to check? may be 1,4 ?Leave a comment:
Your board is different from the DPS-167CP I was using Your board is a DPS-162KP, I was going by the original post titleLast edited by R_J; 05-20-2022, 03:58 PM.Leave a comment:
No the transformer is connected as in the schematic.Leave a comment:
[QUOTE=R_J;1134903]Check the transformer winding between pins 4 and 5, it should be almost 0Ω, then check the resistors R7908,R7909,R7913, if they are good, check the diode D7904, also check the zener diode D7909
7909 not prsent on my board . R7908,R7909,R7913,D7904 checked all ok. but if 4,5 on transformer T7901 then his open.Leave a comment:
WHY? because if that feedback winding is open circuit you will not get the boosted vcc voltage to make the ic work.
Look at the schematic, It's pins for this winding are 1&4, on your board they are 5&4, pin 4 is ground, pin 5 connects to D7906 and the 3 parallel resistorsLeave a comment:
transformer T7901 ? Why 4,5 ?Check the transformer winding between pins 4 and 5, it should be almost 0Ω, then check the resistors R7908,R7909,R7913, if they are good, check the diode D7904, also check the zener diode D7909
If these are all good, Disconnect D7908 and pins 3&4 of the optocoupler PC7903 and see if the voltage on pin 4 of ic7903 comes up to about 7 volts. If it does not, I suspect the ic is bad.
It is a simple circuit, and should not be that hard to diagnose.Leave a comment:
If you look at the schematic for the dps-262, you will see the pfc ic ic7801 pin8 gets it's VCC_ON voltage from the emitter of Q7902, The collector voltage is supplied via D7906/C7918. This voltage is only there when the standby circuit is working.Last edited by R_J; 05-20-2022, 03:26 PM.Leave a comment:
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
