LG 50 Inch Plasma 50PS3000 - Picture but no sound
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50 Inch Plasma 50PS3000 - Picture but no sound
    Right ok, so with the buffer removed what do the sustain voltages do ?
    • matyka
      • Jan 2015
      • 179
      • Uk
      Hello,I have the same problem maybe you could help me .
      My tv when plug in has a white flash and no picture (sound ok),If disconect Z-sustain I should have a dimm picture ?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        You need to check the Vs and Va voltages first with your DMM.
        • matyka
          • Jan 2015
          • 179
          • Uk
          Hi,I just checked the buffers and the lower one is shorted to ground .
          Whit the lower buffer off I have nice clear picture top half screen .
          I order lower buffer and see .
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok good work keep us updated.
            • matyka
              • Jan 2015
              • 179
              • Uk
              #26
              All working now,was shorted lower buffer EBR55460101 EAX55460501
              Bad-Shorted IC206 .
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Chris555
                Samsung PN64E550D1F plasma – sound, no picture
                by Chris555
                The TV turns on and works normally for a short time but eventually the video shuts off and only the sound is playing. The problem has been getting worse over the past couple of weeks. Initially, unplugging for a while solved the problem and it worked properly for several hours until the next failure. Now it usually fails after a few minutes and unplugging does not always reset it to a good state. Also, it does appear that using the remote for functions like accessing the menu or changing the video input sometimes causes the failure to occur immediately, though changing the volume seems to have...
                03-24-2022, 05:02 PM
              • willis6732
                Samsung Plasma PN43E450A1F - No Picture / Pop Sound
                by willis6732
                The customer of this TV Heard a pop sound before it went dead.
                The VS and VA voltages turn on imediatly and then slowly die off.
                I got a replacement Y-Board (Large board on the left) from aliexpress and still no luck
                If tested all the IC chipson the board all the way on the left by running meter along the connectors and couldnt find any shorts there...
                I think ive checked most the capacitors for shorts as well as most of the diodes and mosfet/transistors on the big boards.
                https://photos.app.goo.gl/KDyLcgB38Bh699Zr6
                09-26-2023, 06:02 PM
