Cable TV box problem??
  • Mmasters
    • May 2014
    • 13
    Friday we had new cable service installed. The converter box only uses HDMI to the TV.
    First TV was a Sharp 47" that run properly for about 30 minutes then went out with no picture or sound, all it would do is click (relay?) a few times then totally shut down, dead.
    Second TV was an RCA 40" that ran for about 6 hrs. total. It went to good picture, but sound was only static.
    Third TV, after hooking it up and getting ready to program cable remote it started intermittent scratching and static. So without going any further disconnected HDMI and power.
    All TV's were working great before. At this point I'm not looking for diagnostic help with the TV's. My only question is, if the cable box was defective could that cause the TV's to go out as described above? Thank You.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Cable TV box problem??
    First I would check out the other inputs for the TV. See if they work. If they work then yes I would think if three TV's went down on the same input then the cable box might be taking them out.
    • ozzy214
      • Nov 2013
      • 319
      • usa
      Or perhaps the HDMI cable your using is shorted internally. Cheap ebay or dollar store crap!
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        That is possible with a intermittent short.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          this does sound like a faulty hdmi lead or a converter box fault maybe feeding the hdmi port the wrong voltage etc causing the noise and shut down.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
