Vivax 32'' MSD309.8B no picture
+ More Options
Posts
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi guys,
    I have 32'' Vivax TV set that is stuck on red standby, wont turn on, backlight doesn't flash, tried torch test but no luck. I can feel the mainboard chip getting warm, and also the chip on PL.MS6M30.1b is getting warm.
    All voltages from PSU are okay, 12V, 5V, 5Vstby, etc, also there is also voltage on LVDS cable, 1.3V-1.4V.
    Question i have is, on the input to T-Con there is LVDS voltage on "data wires" but there is no 5V or 12V for panel to turn on, also on Inverter board voltage coming from PSU is 24V which seem alright. Status pin on inv board is 0V, VBR-B is 4.7V, ON/OFF is 0V.
    MS6M30.1B
    Inverter
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vivax 32'' MSD309.8B no picture
    You have corrupt firmware on the motherboard epprom/flash chip. Replace the mb or find a replacement epprom with correct firmware.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Thanks Reecey, will try so. Cheers
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        No worries keep us updated its a very common issue on these boards.
        • 6ot4hr
          • Oct 2014
          • 87
          • Croatia
          Btw guys, one general question about LVDS and LCD panels. For LCD panel to work does it need a power supply except the LVDS 1.2 1-3V voltages that are given by T-Con. Ofcourse we are not talking about backlight voltages needed for backlight to operate...
          Any good videos to watch or books to read for recomend?
          • mecha1166
            Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
            by mecha1166
            I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
            07-03-2024, 05:03 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Ollerenshaw
            Samsung plasma tv PN51F5300BF - jerky staticky picture on whole screen until warm up
            by Ollerenshaw
            About 50% of time, on switching tv on, there is a jerky staticky picture over whole screen. After some seconds (variable, 5 to 20 seconds) picture suddenly becomes normal.
            Nothing appears abnormal inside.
            I'm not a service technician. Main questions: Any ideas as to problem? Worth taking to repair technician? My skills would allow replacing a board but nothing more complicated.
            Photos and video attached.
            Thanks for any ideas....
            11-01-2022, 11:55 AM
