Samsung PS42-Q97HD, power supply: BN44-00161A clicking ON and OFF
  • jczarniak
    • Oct 2015
    • 179
    Replaced capacitors (4x1000uF), checked mosfets QX801, QX802, QS801, QS802 - no shorts, fuses OK.
    AC connected:
    5.1V between Stby and RTN pins
    4.2V between PS-ON and RTN
    AC connected, bridge between PS-ON and RTN:
    Relays clicks ON and straight OFF.
    No idea what to do / check next.
    Thank you very much for any help.
  • jczarniak
    • Oct 2015
    • 179
    Re: Samsung PS42-Q97HD, power supply: BN44-00161A clicking ON and OFF
    Mosfets: 11 Ohm between external legs on the bigger ones (QS801, QS802)
    1380 Ohm - QX802 (between external legs)
    2.4 kOhm - QX801
    Anything wrong here, please?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Are those readings with the mosfet in circuit. Better to test with it removed and meter set to diode mode. What's its part number?
      • jczarniak
        • Oct 2015
        • 179
        Mosfets still in board.
        Checked in diode mode (still in board):
        First one: 0.645, second one over the range.
        Looks like these two has been replaced in the past.
        FDPF 18N50T
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          You should be able to measure the diode in one direction with all other measurements OL
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Watch this if the mosfets are not blown, common issue on these boards is broken solder joints:
            https://m.youtube.com/watch?v=JjQ--2SZdyY
            • jczarniak
              • Oct 2015
              • 179
              Removed two surface mounted diodes: DX803, DX804.
              One looks fine, other one: over limit in diode mode, 5kOhm in resistance mode.
              Power supply still clicks On and OFF without them diodes. Is this OK?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Thats fine, have you checked the solder joints on the devices on the middle heatsink ?
                • jczarniak
                  • Oct 2015
                  • 179
                  Yes, re flowed etc...
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Hmm ok then have you tried disconnecting the sustain boards see if the Psu stays on ?
                    • jczarniak
                      • Oct 2015
                      • 179
                      Yes.
                      I've got the power supply out of the TV now.
                      CN807 connector, stby, VS-on, PS-on pins; there are pins marked 5.3V, I've got only 1.42V. Is this OK?
                      • jczarniak
                        • Oct 2015
                        • 179
                        Connector CN801, AMP etc, on pins 5.3V and 12V I've got 1.4v.
                        • jczarniak
                          • Oct 2015
                          • 179
                          Va test point 1Volt
                          • jczarniak
                            • Oct 2015
                            • 179
                            Vg - 1.4 V
                            Vs - 0 V
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Video at
                              https://youtu.be/za3EixgxBkk
                              Which may be of help.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                There's a repair kit available
                                http://www.coppelltvrepair.com/p/1/b...r-the-va-tract
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Ok so your Vs supply is dead, as you said the fets were changed have you checked the fuse for them ?
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    FDPF 18N50T
                                    Both mosfets should show diode between D-S
                                    Are you sure that the second mosfet is not open circuited.
                                    • jczarniak
                                      • Oct 2015
                                      • 179
                                      Fuse is fine
                                      • jczarniak
                                        • Oct 2015
                                        • 179
                                        Both mosfets:
                                        red probe on S, black on D, diode mode, reading: 563
                                        reversed probes: no readings on both mosfets.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                          09-07-2024, 05:50 AM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                          03-31-2024, 02:12 PM
