Hi All,
I've been given the above TV to repair if possible.
I'll dive right into it if I may.
PANASONIC TH42PX8E
Fault behaviour:
Firstly turning on the TV - First two times I got a Picture - the OSD stating no source found - what you would expect to see during normal operation without an aerial attached.
After maybe 60 seconds the picture cuts out, and I am presented with a sequence of 12 blinking lights
I again turned on the TV. Same result, however I was watching and noticed that a green square ran across the very top of the screen.... and then 12 blinking lights.
Now a quick google and it would appear that the fault is with what's known as the A board.
Before I committed to opening up the TV, I ran through the one/off procedure... now each time I am only getting 9 blinking lights - no picture.
This fault code means Panel Config SOS.
This is where I'm stumped.
First couple of times I got picture before a 12 blinking light failure.
Now each attempt is 9 blinking lights.
I'm unsure what exactly Panel Config SOS means as the Technical Manual doesn't really state what to troubleshoot... can anyone help?
I'll leave the Power lead removed while I'm asleep and re connect to see if I can again get a picture tomorrow.
PANASONIC TH42PX8E
Fault behaviour:
