Sony KDL-46XBR5 "RIP"
  • dogdad
    • Nov 2015
    • 35
    • usa
    The TV was brought to me several months ago with bad ghosting and imaging on the upper-right side.
    Turned out to be a TAB-bonding issue. Found the exact bad-spot, and glued/taped it together as best I could (BTW, Check out budm's great thread on repairing tab-bonds!). It held together on the bench running continuously for almost 2 weeks, even with me poking at the repair-area. Finally had enough confidence in it that I re-gifted to my wife's boss, with the caveat that it's 'as-is'. Her kids are big video-game players, so it was a good match.
    Got it back 2 days ago, and she said it was doing the same thing. I was reluctant to work on it as I wasn't sure what I could different do the second time around, but fired it up anyway.
    Now for the Good News & Bad News:
    - Good News is that there wasn't any ghosting.
    - Bad News is the screen was cracked.
    It's a heavy tv and I was surprised at how it had looked like it was just 'tossed' into her minivan when she brought it to me, and i'm guessing that's when/how it died.
    So it's back in the dumpster as we speak.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sony KDL-46XBR5 "RIP"
    I hate people with more money then brains. Poor tv's getting tossed around as they just dont care...
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • dogdad
      • Nov 2015
      • 35
      • usa
      A follow-up...
      OK, since the Sony belonged to my wife's boss, I figured I'd build up a bit of 'employment-insurance' and give them another flat-screen tv that I'd just repaired. I watched as they again 'threw' the new tv in the back of the mini-van, facedown and on top of a bunch of other stuff!
      Jeez, it was like watching someone go out of their way to antagonize an animal.
      I learned my lesson here!
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        End of warranty at least , lol ..Nothing's good as them do the breaking and we the condolences .
        • Cheesesteak
          Sony XBR-55A8G 4K OLED image ghosting/jumping around
          by Cheesesteak
          Hello All,
          Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
          I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
          I saw some people had success...
          04-18-2022, 04:35 PM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • samolo75
          Sony 49XE8096 intermittent ghosting
          by samolo75
          I started posting in a different thread and I was told it was not the best ans the tv model and the fault did not match. I am copping here what I wrote.
          After starting the TV it works ok for a few seconds and then starts showing ghost image with horizontal lines intermittently (except the very top). The frequency of the ghosting is steady, like every second or so, it goes from normal to ghosting every second and back.
          The TV is a 49XE8096. I already did quite a lot of trouble shooting. And I got the doubt if the problem is in the panel or de Tcon.
          When disconnecting...
          02-04-2021, 01:10 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
