TH-P42VT30 - 6 blinks
  • Telefixer
    • Mar 2015
    • 11
    • New Zealand
    Hi All.
    I've got a 42ST30Z. It's a New Zealand model. When I first got it, it was dead. I replaced the mains fuse and two chopper transistors on the P board. As the SN board was shorted, I found dead IGBTs so I did the normal check for a burnt screen and damaged buffer boards before I then changed the usual IGBTs and their diodes. Turned it on, and hello 6 flashes, 8 if I disconnect the flat control cable SN20.
    Very pleased with myself when I found one of the little driver ICs, IC501 and 502, had a shorted output. Replaced them, still 6 blinks!
    (SN board is SC plus SD and SU on one board)
    I do have a 50VT30 to compare it with, BUT, has anyone come across this before? I'd love to know what you found. If I fix it I'll be posting. i must be close!
    Cheers
  • tw2005
    • Oct 2011
    • 6458
    Re: TH-P42VT30 - 6 blinks
    Originally posted by Telefixer
    Hi All.
    Cheers
    If the driver was shot then good chance the npn/pnp driver transistor was also shot and you would also check the gate resistors too.
    What pins were shorted on the driver IC? What transistors were replaced?
    • syaoran123
      • Jun 2014
      • 178
      http://alpengeist-tvrepair.blogspot....330-board.html
      • Telefixer
        • Mar 2015
        • 11
        • New Zealand
        Thanks TW2005 - Replaced IC502, as pin 7 (output) weas shorted. Checked Q531 that it drives, lifting two legs, and it measured okay. Resistors measured okay, but I might just replace the double transistor Q531 anyway.
        The transistors I replaced were the normal Q401 etc and Q421 etc IGBTs.
        I note that usually there's only one or two of these IGBTs shorted, but I think it's a good idea to replace them as a set, 'cos you don't know how close they got to going also.
        syaoran123 - Good stuff there two thanks, I'll check out the extra transistor that blew for you giving you 6 blinks.
        Thanks for the help guys - I'll post more when I have more - be mon or tues I think
        • syaoran123
          • Jun 2014
          • 178
          6 blinks could also be a bad soldering of the driver IC. May need to check the pin connections and/or check for bridges etc.
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • osrex
            LED DRIVER KEEPS DYING
            by osrex
            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
            i have no datasheet at all for the LED lights, all i have is its length.
            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
            05-05-2025, 03:36 PM
          • Yanleb
            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
            by Yanleb
            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
            D608, good
            D618 RF101L4S, good (See warning 1 below)
            D619 RF101L4S, good (See warning 1 below)
            D865 RF101L4S, shorted (See warning 1 below)
            IC464 Inverter HA MC74HC1G14, shorted...
            03-09-2020, 12:00 AM
          • howardc64
            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
            by howardc64
            Problem
            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
            Model & Board Pics
            Conflicting Spec
            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
            https://www.shopjimmy.com/vizio-gj-2k1...
            10-10-2024, 01:16 PM
          • modtool
            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
            by modtool
            Hi to all,
            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
            04-01-2025, 08:22 AM
