toshiba 58l4300uc no back light
  • tonytiger
    • Jan 2010
    • 163
    • canada
    hi everybody,
    i have this toshiba 58l4300uc that when power on will just quick flash and green power lead stay on(green)
    checked with flash light test and yes i have picture in the back..
    i also checked all my voltage on power board and i do have my 5v and 12v where all indicated.
    the only place i missing voltage is on one line(lB1-)0v
    but i do have all voltage on lB1+ to lB5+ (power on 127v on all/power off and on again it goes to 200v and come back to 127v)
    on lB1- ov but on all the others(lB2- to lB5- i have 18.4v
    i did check the Q907b,Q907c,Q907d,Q907a black lead on panel and red lead pin on left and pin on right on all these giving me 12v
    but Q907e giving me 0v on left or right side pin.
    so i presume i do have a problem here....is there a way to check this line,i been testeing all small parts around it and in the back and they all seem to be ok....
    i have no diagram for this tv. and also wondering is there a way to bypass my back light to test and how.
    by the way i did took the front panel out and did a check of all leds individual with the 3v and was all ok. and also did a 135v or more on each 5 stipe led and the stipe led all came on ok.
    by the way this is my first post so please if i do something wrong,please let me know,thank you.
  • CapLeaker
    Leaking Member
    • 8320
    Re: toshiba 58l4300uc no back light
    Since you tested out the LED strips,is the led driver Q907e shorted?
    BTW, pretty good troubleshooting for a first poster.
    • tonytiger
      • Jan 2010
      • 163
      • canada
      thank you,since i been reading alote,i guest i been learning more than in school,and i do have to say you guys are very helpful also.
      yes i did check the q907e onboard and i did took it out of the board and tested ok,and i even swamp it with q907d to make sure and q907d(with my old q907e) tested ok( 12v) but my new q907e(good q907d) was still 0v.
      so i do know that this q907e is ok but must be something in this line,but with no diagram it is had to see....
      • CapLeaker
        Leaking Member
        • 8320
        check transistors Q902(x). there are 5 of them. The bottom left one on your 4th pic. Pic is a bit blurry, but it looks like Q902E. Check U901 on pic4.
        What transistor is Q907? There should be something printed on it.
        What is U901?
        • tonytiger
          • Jan 2010
          • 163
          • canada
          ok,sorry for delay
          i took some more photos in case,but as for the small transistors in the back q902e,tested ok and same for the 4 others,tested all the same reading.
          as for the numbers printed on it,like you will see,i been trying alot of thing to try to read it but no luck.
          and for the ic u901 (9908bgn
          cd7318.2n
          1302a2
          is the number.tested all the small cap and res,ect....all around that so i guest it will be this ic,but still weired that only on line of led not receiving power from here....
          • CapLeaker
            Leaking Member
            • 8320
            I can't read it. An oz9908agn maybe?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I think it's an OZ9908B from O2Micro
              https://cdn.badcaps-static.com/pdfs/...6f8b3d4b96.pdf
              • tonytiger
                • Jan 2010
                • 163
                • canada
                yes i think your right with that number,it is very hard to read.
                i will try some other test since you provided me the chip info tonight.
                but at this point i guest the best thing will be buying a new power board.....
                i let you know.
                thank you very much guys for replying fast,very appreciated.
                • Mayn
                  • Nov 2016
                  • 54
                  Sorry to hijack this thread, but I can't start a new one yet.
                  I have this same tv, and I get picture. The problem is I can't adjust the brightness. It started flashing between normal and dim, and now it just stays dim. not black, just dim, and I can't adjust it to be brighter.
                  Any ideas?
                  • Mayn
                    • Nov 2016
                    • 54
                    The image is perfect, no dark spots or anything. no obvious issues. I picked this up from someone else who already had the main board replaced and the problem was still there.
                    • Mayn
                      • Nov 2016
                      • 54
                      Measured 114v on output from power supply to all led strips, and 3.4 on the BLON. Don't see anything labeled as DIM on this set.
                      Since the voltages seem fine, and the main board has been replaced with no difference, could a bad t-con board cause this? As i said, the image is perfect everywhere, just dim.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        No backlight symptom is not a T-CON Bd problem...and since you do see a pic with the 'flashlight' test...this proves good T-CON Bd..... Look at the LEDs again and the interconnectors as well as the connector from PSU to LEDs....test each LED individually...Trace the source of that missing B1 voltage.
                        • Mayn
                          • Nov 2016
                          • 54
                          The only thing that seems odd to me is the measurement I get on PWM on the P802 connector. I only get 0.4V. Any suggestions?
                          • Mayn
                            • Nov 2016
                            • 54
                            I don't need to do the flashlight test as I have an image on the screen. just can't make it brighter
                            • Mayn
                              • Nov 2016
                              • 54
                              Seems from looking around on these forums that PWM should be around 2.5V, so I'm guessing that's the problem. Anywhere I can 'steal' that from to make it work?
                              • tmhobadcap
                                • Apr 2019
                                • 156
                                • CANADA
                                I have the same model tv and the same backlight problem. (But strange, the led is 6V instead of 3V.) I found the problem was poor connection at one of the interconnectors.
                                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                  by sam_sam_sam
                                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                  I am comparing them to a brand new one that I installed
                                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                  I going to let it run for several days before I remount back on the wall next to the...
                                  09-05-2024, 06:48 PM
                                  09-06-2024, 05:27 AM
                                • PNI E.
                                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                  by PNI E.
                                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                  02-20-2025, 08:36 AM
                                  09-06-2024, 05:59 AM
