Polaroid TLAC03212 Lost power in Lightning Storm
  • culcuhain
    • May 2016
    • 186
    • U$@
    Good morning!
    My friend gave me this Polaroid TLAC03212 32" tv for free since it lost power in a thunderstorm. I know it would not be just a fuse, we can never be that lucky.
    Here we go...
    Fuse was indeed dead. I ordered about 10 (in case I blow a few testing...) and desoldered and soldering in the new fuse. Plugged in the Power board and no 5v stby. The fuse did not blow. Checking the bridge rectifier I have 120V on the AC inputs and ~164 on the DC outputs. The Large cap (450v ?82uf) has ~160v DC.
    Not sure where to go from here and I cannot find the service manual for this freebie. I am getting better and I appreciate everyone's help!
  • CapLeaker
    Leaking Member
    • 8226
    Re: Polaroid TLAC03212 Lost power in Lightning Storm
    You would have to fix that 5V STBY voltage first, if the PSU doesn't have any STBY voltage.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      If the fuse was blown but a replacement did not blow, then it is likely that you now have an open circuit device or failed IC. I would test all the diodes and zener diodes to start with.
      • culcuhain
        • May 2016
        • 186
        • U$@
        I have attached a pic of the board and the diodes I tested with my DMM.
        When set on diode (tested on board, did not left a leg) all diodes had voltages <1v when the probes were attached, both Black on Diode line side and reversed, with the exception of one. This one showed OL when the red probe on the Line (reversed, I know) so I pulled it and tested it again. Same result, diode should be good.
        I did not check any of the SMD diodes on the backside. So I check those next?
        Is there a certain trace to follow and test until we find out why there is no 5v standby (I am not worrying about the other voltages at this time.
        Many thanks!!
        • culcuhain
          • May 2016
          • 186
          • U$@
          Looks like I found the culprit. Mosfet at Q23. Tester showing it as 2 resistors and not a Mosfet. Part # JCS2N65F. Mouser and Digikey has one close but the RDs Drain Ohms is lower from them. Will that be a problem? I appreciate everyone's help!
          • CapLeaker
            Leaking Member
            • 8226
            That mosfet should be shorted if it is bad. Now you have to check the gate drive circuit of the mosfet. Make sure the resistors are still within its specifications, diodes aren't shorted, etc. If you have to order that mosfet, make sure you don't have to order that PWM IC later. Not that the PWM is automatically have to be bad, but its a bummer if it doesn't work and you have to do another order because of a 1$ part that cost 8 to 25 to ship.
            • culcuhain
              • May 2016
              • 186
              • U$@
              Thank you for the tip about the PWM IC. I will get one ordered. Yeah. Ordering a $1.37 part and paying $8.00 for shipping doesn't make sense. I have a few more friends dropping off tvs for me to fix. so I will just do one order if possible.
              • CapLeaker
                Leaking Member
                • 8226
                make sure that all components on the path between the PWM and the gate of the Mosfet are good.
                • culcuhain
                  • May 2016
                  • 186
                  • U$@
                  MOSFET and IC (forget which one, been awhile) replaced and tv lives.
                  • CapLeaker
                    Leaking Member
                    • 8226
                    Perfect!
                    • corrize
                      A funny fuse story – Lumix LX100 II
                      by corrize
                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                      10-19-2023, 09:58 AM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
                    • jshhh
                      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                      by jshhh
                      Hi guys,
                      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                      Anybody know how to remove this type of fuse?
                      (The fuse is toward the bottom of the image labeled F2)...
                      06-17-2025, 01:35 AM
                    • Babbar
                      by Babbar
                      04-12-2024, 01:12 AM
                    • drykid
                      Matsui 175S microwave fuse replacement
                      by drykid
                      I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                      Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                      12-21-2020, 01:15 PM
