Samsung Plasma PN51D550 3D TV X/Y boards
  • Sevenqi
    • Jul 2011
    • 292
    I have some X/Y boards for Samsung 50 plasma TV, some of them are 1080P (DF),some are 720P(DH), piled in my garage for long time. Today I happened to have time to repair and test against PN51D550 (1080P 3D TV).
    I checked the boards all seem to have IGBT transistors blown.
    I fixed some of them only due to not have enough transistors.
    Part Number: LJ41_09422A (X) ,LJ41_09423A (Y).
    Y board (DH)+X board (DH), TV works. (720P boards work for 1080P).
    Y board (DF)+X board (DF), TV works. (original).
    Y board (DF)+X board (DH), TV works.
    Y board (DH)+X board (DF), TV not work, X and Y boards both burnt IGBTS again.
    I don't have the 720P(PN50D450) TV so don't know if DF XY board works.
  • cndnheat
    • Dec 2016
    • 3
    • CANADA
    Re: Samsung Plasma PN51D550 3D TV X/Y boards
    Do you still have these boards?
    • Jsolts
      • Dec 2016
      • 7
      Would any of these boards work for a PN51D450A2D?
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • C152Heavy
        by C152Heavy
        Summary for TL-DR readers:
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
        09-07-2024, 05:50 AM
      • Nicktronic
        Samsung Power Supply Board BN44-00874F
        by Nicktronic
        Hey everyone,
        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
        Anybody...
        03-17-2025, 06:20 AM
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
