Baird jo47.
  • benjamin.d.bird
    • Jun 2016
    • 45
    • United Kingdom
    Baird jo47.
    I have This TV, all of a sudden it gave me problems getting out of stand-by, (red light would just flash away).
    So I replaced 5 of the Capacitors, Now the unit switches on from stand-by quite happily.
    However, Now the screen appears to be extremely bright pinkish white. Can still see the image displayed on screen, the picture seems like a negative.
    entered Factory Mode (source 2 5 8 0) no eprom reset option there,
    so where do i go from here?
    Any help/Guidance will be greatly appreciated
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Baird jo47.
    Check this out, might just need a reset:
    https://www.badcaps.net/forum/showthread.php?t=50688
    • benjamin.d.bird
      • Jun 2016
      • 45
      • United Kingdom
      Re: Baird jo47.
      Hi and thanks for the reply.
      Although I don't know if it would make much difference, the screen on this unit is CMO.
      I've managed to get into the menu (source 2580) but unfortunately there is not a reset option, only thing available is "shipping mode".
      I was informed that I more than likely have corrupted firmware, and was told to look for a bin file. I have found one which I will attach, however I am not 100 percent certain that it is the correct one, not to mention that I require a pointer on how to flash it as there are not any usbs on the unit.
      So any help and advice I will greatly accept!
      Regards
      Ben.
      • benjamin.d.bird
        • Jun 2016
        • 45
        • United Kingdom
        Re: Baird jo47.
        Also noticed that two settings are set to "off" position, they are:
        ssc miu and ssc lvds
        Is this correct
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Baird jo47.
          Maybe have a play with the Lvds settings first before ordering an epprom. Also have you got an image of the service menu please ?
          • benjamin.d.bird
            • Jun 2016
            • 45
            • United Kingdom
            Re: Baird jo47.
            I e taken a picture of every menu and sub-menu
            • vinceroger69
              • Mar 2012
              • 6714
              Re: Baird jo47.
              i wonder if this is a gamma ic problem? i know reece had one a while ago on a 47 in set although was a diffrent baird model number so maybe newer.
              • benjamin.d.bird
                • Jun 2016
                • 45
                • United Kingdom
                Re: Baird jo47.
                For some reason the attachment didn't upload
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Re: Baird jo47.
                  Thats the thread I linked, turns out it was the firmware lol
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Re: Baird jo47.
                    your link looks like that firmwares for a lg screen looking at the panel sticker in your picture its a cmo screen
                    or this from ohms supplies
                    http://www.ohmsupplies.co.uk/JO47-BA...GRAMMED-EEPROM for cmo screen only
                    please note though this may not be the issue with your tv so its up to you if you want to try it.
                    • benjamin.d.bird
                      • Jun 2016
                      • 45
                      • United Kingdom
                      Re: Baird jo47.
                      In the PIC it says cv109h v1.1 where mine is a v1.2, would that make a great difference
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Re: Baird jo47.
                        im not 100% sure maybe send them a email and ask they are a good company ive used them a few times.
                        but just too be clear the eeprom may not be the issue with your set so its up to you if you want too go down this route and try it.
                        • benjamin.d.bird
                          • Jun 2016
                          • 45
                          • United Kingdom
                          Re: Baird jo47.
                          Hi Vince,
                          Many thanks for your advice, I'll leave the replacement eeprom on the back burner for now.
                          As for my next step...... I'm totally lost, where would you suggest that I go from here?
                          Regards
                          Ben
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Re: Baird jo47.
                            im not sure myself lets see what the others think a factory reset may of sorted it but i cant find any information regarding this starting with the basics do all of the power supply voltages test ok etc.
                            • Diah
                              • Feb 2013
                              • 6366
                              Re: Baird jo47.
                              i just wounder you had replaced 5 caps where they are ? and you didn't mentioned on VDC reading did you measure them if they are fit enough to support the main boards video process ??
                              • benjamin.d.bird
                                • Jun 2016
                                • 45
                                • United Kingdom
                                Re: Baird jo47.
                                I attach a photo of the caps that I have replaced, the two that are together (ec9 & ec10) had obviously gone, the other 3 (being ea3, ec2, & ln2)
                                • benjamin.d.bird
                                  • Jun 2016
                                  • 45
                                  • United Kingdom
                                  Re: Baird jo47.
                                  Reece do you have any idea what the settings should be?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Re: Baird jo47.
                                    Sorry I cant open the picture of the service menu ? Same board as mine so you might not have done it right. Also the Psu is fine its the mb for sure.
                                    • benjamin.d.bird
                                      • Jun 2016
                                      • 45
                                      • United Kingdom
                                      Re: Baird jo47.
                                      I've re uploaded them
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Re: Baird jo47.
                                        Go into factory setting if I remember the reset option is there.
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
