Samsung main board BN97-05375B 0078 EEPROM Reset?
  • KenOlson
    • Jun 2011
    • 81
    A friend has a Samsung LED TV model UN32EH4003FXZA that has an Over the Air Station Search Loop (keeps repeating Chan 14 and can Not get out using Mute>1>8>2>Power On).
    After much searching we found "UnBricking TV by EEPROM Reset" https://wiki.samygo.tv/index.php5/Un...y_EEPROM_Reset
    The Samsung TV Main Board Sticker is BN97-05375B 0078
    L6 C 08/08/2012 20:56
    We are trying to determine where the EEPROM Reset is on this Main Board?
    While "UnBricking TV by EEPROM Reset" does have photos for many different Samsung TVs we could Not find any similar to the BN97-05375B 0078 board.
    We also searched using "BN97-05375B 0078" and found "Samsung BN94-06008X (BN97-05375B, BN41-01876B) Main Board"
    http://www.shopjimmy.com/samsung-bn9...eh4003vxza.htm
    Should mention we have done a number of searches to try to find the Samsung LED TV model UN32EH4003FXZA Service Manual but have found Nothing to date.
    Appreciate any Help!!!
    Ken
  • victor_cj
    • May 2015
    • 90
    • Romania
    Re: Samsung main board BN97-05375B 0078 EEPROM Reset?
    IC901 is the eeprom.
    Eeprom software: SAMSUNG_UE32EH4003W_24C256_IC901.BIN - 32.0 Kb
    The art of fighting without fighting
    • Diah
      • Feb 2013
      • 6565
      when its on turn your TV to standby state, leave it round 30 minutes or more. then plug it on if it switched to Chanel search again immediately you have RF Quartz defect, if no, then go to menu to make Factory reset. after factory rest if didn't help back to fault RF parts Quartz defect or crack soldering.
      eeprom reset via service menu you need Samsung service remote, also there are apk on google play can do this with any mobile had Infrarot sender
      • KenOlson
        • Jun 2011
        • 81
        Hi victor_cj,
        Thank you for identifying eeprom as IC901 and eeprom software link!!!
        Please excuse my Bad English "We are trying to determine where the EEPROM Reset is on this Main Board"
        Should have said "are trying to find the 2 jumper holes so we can do the eeprom reset.
        This video may explain it better "samsung smart TV D5700 eeprom reset, bootloop, boot schleife, factory reset" https://www.youtube.com/watch?v=DDzOSdfA41s
        Except could Not find the jumper holes that he used (video ~ 1:40 to 2:25 minutes).
        Thanks again for your help!!!
        Ken
        • KenOlson
          • Jun 2011
          • 81
          Hi Diah,
          Will do as you instructed and tell you the results.
          Thanks for your help!!!
          Ken
          • KenOlson
            • Jun 2011
            • 81
            Diah,
            "there are apk on google play can do this with any mobile had Infrarot sender" Thanks for tip!!!
            Checked the Google Play Store and there are a number of apps.
            Do you have a favorite?
            Ken
            • victor_cj
              • May 2015
              • 90
              • Romania
              The holes marked with red must be united.
              M_E_SCL and M_E_SDA.
              • Diah
                • Feb 2013
                • 6565
                Originally posted by KenOlson
                Hi Diah,
                Will do as you instructed and tell you the results.Thanks for your help!!!Ken
                download the apk from this archive at this threat https://www.badcaps.net/forum/showpo...8&postcount=19
                • KenOlson
                  • Jun 2011
                  • 81
                  Diah,
                  Here are results for "when its on turn your TV to standby state, leave it round 30 minutes or more. then plug it on if it switched to Chanel search again immediately you have RF Quartz defect"
                  To make sure I left on Standby for 4hours. When then turned on TV went immediately to Chanel search.
                  Ken
                  • KenOlson
                    • Jun 2011
                    • 81
                    victor_cj,
                    Thanks for posting photo of which holes to connect!!!
                    Does anyone have suggestions/tips when do a board reset?
                    Ken
                    • KenOlson
                      • Jun 2011
                      • 81
                      Diah,
                      Have downloaded the Android LG remote app.
                      Checked the files but did not find a User Guide/Manual?
                      Is there anything I can read concerning it?
                      Ken
                      • Diah
                        • Feb 2013
                        • 6565
                        sorry i may missed by typing, when you turn it to standby state, you should plug it out from wall socket and then after while plug it on.
                        the apk only install it on android device with IR sender, and choice TV Samsung, after that you will have the option to press on service menu at the apk.
                        • KenOlson
                          • Jun 2011
                          • 81
                          Diah,
                          Clarification concerning "...when you turn it to standby state, you should plug it out from wall socket and then after while plug it on."
                          Normally I turn the Samsung TV off (standby state) and then unplug it from wall socket"
                          Before doing what you instructed the TV was unplugged for ~3 days. When plugged into wall socket was in standby state for 4 hours and when then turned on went immediately to Chanel scan.
                          Ken
                          • KenOlson
                            • Jun 2011
                            • 81
                            victor_cj,
                            I took a Samsung main board similar to yours (attached) but not as good.
                            What did you use to take the photo.
                            Ken
                            • KenOlson
                              • Jun 2011
                              • 81
                              Diah,
                              "the apk only install it on android device with IR sender, and choice TV Samsung, after that you will have the option to press on service menu at the apk"
                              I have a Samsung Note 3 that should work.
                              I like to read the user guide/manual. Is there anything that either shows or describes the feature of this app
                              Checked Google Store and searched using "LG Remote" and found a number by LG Electronics.
                              https://play.google.com/store/apps/d....tv.remoteapps
                              https://play.google.com/store/apps/d...mm.WiFiRemocon
                              https://play.google.com/store/apps/d...d=com.lge.app1
                              Many other by third parties.
                              Ken
                              • KenOlson
                                • Jun 2011
                                • 81
                                Beginners question concerning video "samsung smart TV D5700 eeprom reset..." https://www.youtube.com/watch?v=DDzOSdfA41s
                                ~2:50 min mentions ...LED backlight longer than 20 seconds on...success??? Later shows was success.
                                Is 20 seconds the recommended time for Samsung LED TV eeprom reset?
                                Ken
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  this may help im not sure how to use this app i didnt know it can do samsung tvs as well maybe a more experienced member whos used this can help use with a step by step guide on how they got this app to work etc
                                  https://www.youtube.com/watch?v=F7_LHqWZoxM
                                  • KenOlson
                                    • Jun 2011
                                    • 81
                                    Forgot to mention have been searching the forum for information concerning "eeprom reset".
                                    After reading "...glad no EEPROM reset was necessary as it is quite tricky..." by tom66 https://www.badcaps.net/forum/showthread.php?t=18199 decided it may be wise to ask for any tips/suggestions.
                                    Thanks again for all your help!!!
                                    Ken
                                    • victor_cj
                                      • May 2015
                                      • 90
                                      • Romania
                                      12 seconds is enough.
                                      There have been situations when the problem was caused by BGA connection from Scaler or flash nand memory with bad blocks.
                                      • Diah
                                        • Feb 2013
                                        • 6565
                                        in the archive i call it LG but its the apk name Smart Remote, its handle allot of TV brands , projectors, HIFI, etc. and others home electronic sets, by TV all had access to service menu, and special service menu too.
                                          09-07-2024, 05:50 AM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
