Sony google tv nsx-40gt1 3 red ligth blinks
  • hmendez86
    • Jun 2015
    • 344
    • united states
    THIS IS A GOOGLE TV THEIR ARE BIT RARE TVS. WHAT IT DOES I CONNECTED TO AC AND CLICKS 3 TIMES LIKE TRYING TO TURN ON AND RED LIGHT COMES ON 3 BLINKS. SONY GOOGLE TV- nsx-40gt1.,,,THERE'S SOME RESISTORS THAT BEEP ON CONTINUITY...,, I THINK THEY ARE FUSE RESISTORS ONE OF THE SEVEN WONT BEEP ON CONTINUITY ANY IDEAS...
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sony google tv nsx-40gt1 3 red ligth blinks
    First off:stop YELLING. Second:Pictures,we need pictures. "some resistor beeps,others don't" really doesn't say much. Pic from general back setup,one of each board and maybe a close up with arrows pointing t the mysterious resistors that beep?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • hmendez86
      • Jun 2015
      • 344
      • united states
      The red circles are fusible resistors and on continuity the beep even if out of circuit, don't know much about this resistors. One of them which is in the middle is a fuse I think is good beeps on continuity......the blue circle is the one won't beep even if it's out of circuit, and it's a 104j resistor....
      • jason123
        Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
        by jason123
        Hi there,
        I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
        So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
        I see 2 posts that are relevant:
        https://www.badcaps.net/forum/troubl...j-oled-5-blink
        https://www.badcaps.net/forum/troubl...g-hardware-dev...
        10-29-2025, 02:01 PM
      • matwan
        Sony XR-55X90J 5 blinks
        by matwan
        I have problem with SONY 55X90J. After several check status is as below;
        1. Running power board as stand alone:
        TCON_12V =~ 12.6V
        EVDD V On Max 24V= 19V.
        2.
        Running power board with TCON as stand alone:
        Effect as below, attched.
        3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
        "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
        Best regards....
        09-28-2025, 04:26 AM
      • GoodCapDude
        Sony XBR-75X940E intermittent 6 blinks error code
        by GoodCapDude
        Hi everyone. First post on Badcaps!
        I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
        09-20-2025, 06:07 AM
      • AK_777
        Sony KD-65A1 Repair – 4 Red Blinks Error
        by AK_777
        Hi everyone!
        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
        02-20-2025, 04:15 PM
      • jchon
        Sony A1e 5-blinks help
        by jchon
        Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
        I found the service manual, which was critical to know where to probe.
        https://www.manualslib.com/manual/20...1e-Series.html
        With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
        Unfortunately the 5-blinks...
        06-28-2023, 11:52 AM
