Testing for a Broken Screen?
  • SLK001
    • May 2014
    • 264
    Does anyone have a way to test for a broken LCD screen prior to purchase? I'm talking about TVs that have died on the previous owner and they are selling it for a song. Of course, the TV doesn't power-on, so that way is out.
    I purchased a Samsung 40" that was supposed to be okay (except it didn't power on). After fixing the power supply (capacitors) and firing the thing up, there was a crack across the screen. I've tried various ways of looking for a cracked screen, but I have succeeded with none of them.
    I've just been chalking the bad ones up as "you win some, you lose some". I like to sell whole TVs locally, as I don't want to deal with the people who claim that I sold them a board that doesn't work (the "skeet" shooters).
  • japlytic
    • Oct 2005
    • 2086
    Re: Testing for a Broken Screen?
    I find using a bright torch can often reveal breaks in the panel - unfortunately, this technique not work on true LED panels (aka AMOLED/Retina).
    But detecting LC material loss is a bit difficult (before the LCD displays anything) in my experience.
    • ecking767
      • Oct 2009
      • 492
      the good old sun light !! I will carry the TV outside and let the sunlight shine onto the LCD screen facing up to toward the sky. you may need two person to do this.
      you live in the sunshine state, me too !!
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Spraying a little glass-cleaner on the screen plus a good light shows up most busted screens...
        TELEFIX
        • johns1mj
          • May 2015
          • 242
          I have not found a way yet. I usually buy them for less then the interior boards are worth. If I can fix it great if it is a bust then I can break even with parts sales.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
          • Dancauac
            820-01598 EDP cable was disconnected whist testing new screen. No image, no backlight
            by Dancauac
            MBP2019 A2159 Board 820-01598
            Hi Everyone! My very first question and ask for help! Thanks in advance!!!
            I was testing the new screen on this MBP but the time I was maging to turno the mac over, the EDP cable got loose.
            I disconnected the power, reconnect de EDP cable, holding with screws the screen this time.
            Turns on fine, everything works fine, but no image (I used the flashlight) and no backlight at all.
            Done SMC and PRAM reset. Nothing changes.
            Tested other functional aftermarket and original screens. Nothing changes.
            Don“t...
            03-29-2023, 02:38 PM
