Panasonic tx-p50x60b 7 blinks
  • comptek
    • Aug 2013
    • 606
    Hi guys got this in today and it has 7 blinks, i checked over the sn board, there are no shorts on the fets or the big DAF304 diodes...
    Disconneted all cables to sn board, green lights flashes very quickly then goes to 6 blinks
    test point voltages are as follows
    TPNS1 = -232V THEN DROPS
    TPVAD = -232V THEN DROPS
    SRV VFO = -232V THEN DROPS
    SRV VF5V = -232V THEN DROPS
    SRV P15V = 15V THEN DROPS
    SRV VSUS = 184 THEN DROPS
    SRV LED LIGHTS BUT LOOKS DIM
    does this mean the sn board is shot ?
    regards Gary
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic tx-p50x60b 7 blinks
    Test Vs Us input for S/C to Gnd on SN also do the same for SS if shorted, the boards are failed. 7 blinks normally is SN alot of the time.
    • comptek
      • Aug 2013
      • 606
      Reece you on about the (power plug pins to ground on the board) ? if you are theyre ok
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yes yes
        • comptek
          • Aug 2013
          • 606
          Yes yes
          theyre fine
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Is that testing across the plug ?
            • comptek
              • Aug 2013
              • 606
              looking at the white plug ground to chasis
              heatsink heatsink
              plug
              1 2 3 4
              pin 1 grnd 0 ohms
              pin 2] ==== 110k ohms
              pin 3] ==== 110k ohms
              pin 4 O/L
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok so looks like nothing is S/C to Gnd then. Before it shuts off does the screen appear to glow at all in a dark room mate ?
                • comptek
                  • Aug 2013
                  • 606
                  nope just rapid green then 7 blinks
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Find TP, VFG....
                    Ohm out that to all the Buffer Socket Connections. I had one of these with a dead buffer-chip, doing the seven blinker shuffle!
                    Problem is--the Orrible black goo they use on the Buffer-chip pins is Very hard to remove--Unlike the earlier grey silicone, I buggered the board trying to remove the chip, ended up buying a replacement...
                    TELEFIX
                    • comptek
                      • Aug 2013
                      • 606
                      Originally posted by Alastair E
                      Find TP, VFG....
                      HA HA BINGO!! third buffer chip down short on buffer socket roughly in the middle of it Dam!!
                      but thanks its solved the problem thanks Alastair Mate
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Whooo, you replacing the Ic direct Gaz ?
                        • comptek
                          • Aug 2013
                          • 606
                          nah £9 get another board as Alistair said he screwed the board up so maybe the best option to get another baord
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ok, also might be best to heatsink the Ic's on the replacement board to help prevent future issues.
                            • comptek
                              • Aug 2013
                              • 606
                              yeah defo i have some old heatsinks around
                              • comptek
                                • Aug 2013
                                • 606
                                £9 replacement sn board all up and running
                                • Andre Gilbert
                                  by Andre Gilbert
                                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                  11-20-2024, 08:52 PM
                                • Biruslapio
                                  Panasonic P58V11B 8 and 12 blinks error "fix"
                                  by Biruslapio
                                  Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                  Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                  04-13-2021, 07:13 AM
                                • jm1234
                                  Panasonic plasma TX-P42ST50 - 6 blinks
                                  by jm1234
                                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                  I checked that board for any obvious faults...
                                  05-22-2024, 06:59 AM
                                • Alicat
                                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                  by Alicat
                                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                  Model number is TH-50PZ85U
                                  Power comes on and the red power light stays on solid.
                                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                  I also hear a few clicks.
                                  I also think my parents said there was a thunderstorm and the TV failed after that.
                                  Section 6 in the service manual talks about power and no screen,...
                                  10-30-2024, 10:09 AM
                                • CrewmanRedShirt
                                  Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                  by CrewmanRedShirt
                                  Hello all,
                                  As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                  07-13-2024, 11:02 AM
