LN40A550P3F Power cycling
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all long time i have been dealing with a ton of family issues the last couple months. Finally getting back into the groove. So I have a customer's TV here with the common power cycling on and off. The TV will come out perfect in the picture will be perfect for about 15 seconds and then it was shut down and restart. I already took the liberty of replacing c102 and c131. Also the two voltage regulators ic101 and the one next to it. It is still power cycling. I also reset the eeprom to factory light shorting pin 5 & 6 and now it comes up to the welcome to your TV with a snowy image however it still power cycling. What I have noticed is the buttons on the side or unresponsive. However if I hit the button immediately I noticed that it will respond but then the buttons lock up so if I'm holding down the volume button while the power is coming on it will show the volume bar if I hold down the menu button it will show the menu but after about 2 seconds the buttons lock up. Any ideas?
    By the way I already tried jumping PS on to 5 volts and the power supply is fine. This is definitely a main board issue period no swollen caps and even tested for ESR on the power supply caps that are known issues
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LN40A550P3F Power cycling
    Hello freakaftr8,
    I notice on some threads the suggestion to remove the IR/side button connector and see if that resolves the looping and to also check the supply voltages on the IR board.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • usbdevice
      Acer X223HQ (Version Bbd) on/off-power-cycling
      by usbdevice
      Hi all
      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
      https://www.badcaps.net/forum/showthread.php?t=50657
      https://www.badcaps.net/forum/showthread.php?t=40512
      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
      It's my dad's old monitor. He...
      08-05-2022, 02:21 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
