"Dick Smith" 55" LED backlight issue - model GE6880
  • saqi4u
    replied
    Re: "Dick Smith" 55" LED backlight issue - model GE6880
    Hi am new here i ahve same model haire 55 with tv5001-zc02-01 led backlight not working, its just flash when power on then gose blank.
    on Both LED con anode has 110V if i test with ground to anode'
    if i test on both LED con from anode to cathode 0 voltages
    it mean -v have problem plz help me
    https://www.badcaps.net/forum/attach...4&d=1461991048
    sorry my English is very poor
  • rockit711
    replied
    its a FR307 - 1000V maximum DC blocking, 700V max RMS voltage. 3A rating.
    I don't recall having seen the manufacturers logo before, its a black "R" (with white border) with a smaller white "S" or maybe "5" inside it (creating the holes at the top and bottom of the R) - don't know if that description makes any sense!
    perhaps its just a cheap knockoff and doesn't actually meet the specs of the official FR307.
    replied
    So the snubber diode D112 is bad, good find, may be it is the brand they are using. What is the Voltage rating?
  • rockit711
    replied
    SOLVED!
    the culprit was DIODE "D112" on the schematic.
    Despite showing the correct forward voltage drop for the diode (.46V) under a diode test, and no measurement in reverse, it has ~1.3kOhm resistance across it. would have found it far earlier had I thought to do a resistance test over the diode despite the seemingly good diode test result!
    now, seeing as the 2nd PSU is failing in the same way this diode may well be a weakness in the 55" implementation of this circuit.
    So I was thinking that perhaps it is underrated.
    would it be prudent to choose an uprated diode?
    If so is it the average current or the blocking voltage (or both) that should be uprated? my local electronics store sells FR607 (6 amp version of the part) would getting that be a good idea to hopefully overcome this possible weakness?
  • mmartell
    replied
    Use hot air, a wand if possible so you can isolate individual components.
  • rockit711
    replied
    To revive this thread a bit with new information:
    After putting this into the "too hard" category for awhile I was lucky enough to come across an identical TV with an "intermittent fault" that turned it off after a few hours and needed a few minutes unplugged before turning back on, decided it was worth the risk to buy it cheap as a diagnosis tool and potentially fix 2 tvs at the same time so got it.
    so now for the updates:
    Took the power board from that TV and plugged it into the backlight assembly from the original TV and and it works!
    Then to confirm I put the PS board from the orignial TV into the "new" TV and exact same issue, just a single blink.
    So from this i believe it is relatively safe to conclude that (both) the backlight assemblies are working correctly and that the fault is now confirmed to be in the power board.
    I should also note that the second TV appears to have a pre-failure version of the same fault. After turning off (It took almost 2 days straight use in a hot room before this happened, then it needed to sit for a few minutes before coming back on again) if I shine a torch on the screen I can see that the screen is still running but no backlight, and if I turn it back on immediately it just gives the exact same brief flash. of course if this one sits for a few minutes it all works again.
    Does this give anyone any more insight into what the failed component may be? keep in mind that I've already swapped the OB3364 controller over so its unlikely to be that!
    I was considering just ordering a bunch of parts and swapping almost every component in the LED primary and secondary sides over - would still be cheaper than buying a replacement board (which would then have to be modified anyway seeing as this one had been modified to run the 55")!
    tl;dr LED backlights confirmed as good, fault is in the PSU - still need help isolating the fault.
  • rockit711
    replied
    Swapped out that LED with a good one off another string (actually tried 4 off two different good strings- just to be sure I hadn't damaged them in removal/replacement). ANNDD.... its still exactly the same as before - everything is the same as far as I can tell, measured the various pins and as far as DMM measurements go its all operating exactly the same as with the "bad" LED.
    I have also tested all the other LEDs for resistance, none of the others have a reading on the 2MOhm scale. Also none of the others turn off quickly or before the others etc on my video.
    This one is really stumping me. I would really like to isolate which part is bad - the LEDs or the PS board.
    I was thinking as a way to do this:
    Upping the value of the ISET resistors (circled in picture), to kick in the current limiting part of the driver at a lower current.
    I know every LED works for at least a few seconds at 100mA (battery test showed that) so if I up the resistance to 20 - 30 Ohm on each driver branch (its currently at 8.5 Ohm total combining the two resistors - this differs from the schematics 5Ohm total with two resistors, I suspect because two driver circuits have been paralleled into each string as opposed to the one per string in the schematic) per branch would drop the current limit sufficiently to get the LEDs to work for at least a few seconds (if the power board is good).
    If the LEDs do work then its a bad LED issue. if not its a power board issue.
    Is that a good thing to do, or have I missed something and doing that would be terrible?
  • rockit711
    replied
    Originally posted by SLK001
    Use a hair dryer to warm up the glue holding the lens and it should pop off fairly easily. Use BudM's method of removing the LED if you don't have two soldering irons. If you don't over do it, there is little possibility of doing damage.
    Is there any special glue or anything recommended for re-attaching the lenses?
    Also what is BudMs method (or a link to where it is)? Tried to find it but couldnt see any thing obvious.
  • rockit711
    replied
    Well it didn't turn off for over a minute..
    But then I went to test the next one in the chain (to check the current was still close) and got the wrong test point so it was putting the 3v over 2 LEDs, and oddly the 2nd (good) one illuminated very dimly..
    Turns out the 1st led has indeed failed, has a measurable resistance across it, ~300kOhm. Probably failing totally at peak current output.
    Still no idea why it isn't triggering the drivers protection though.
    Will try swapping in a good LED tomorrow, hopefully this led is all it is.
  • SLK001
    replied
    Apply 3 volts to the suspect LED and measure the current. Hold the voltage for 10 to 20 seconds. Since this LED is the one shutting off prior to the rest of the panel, it should shut off by itself.
  • rockit711
    replied
    Before i go popping off lenses and desoldering LEDs, is there any way to use the test points (they were nice enough to put one on either side of each led)? Would soldering in a second LED with wires to the test points work for testing purposes? Or perhaps a resistor, just something to test if this LED is the cause before doing something potentially damaging .
  • SLK001
    replied
    Originally posted by rockit711
    For testing purposes does the replacement LED have to be identical?
    That usually works. Just be aware that some LEDs have large pad on the CATHODE and some have the large pad on the ANODE. Although one can be flown in on the other's pad, it really isn't a long term solution, as the heat isn't removed as well.
    For testing, I have put down a leaded white LED to test out a TV.
  • rockit711
    replied
    The fault doesn't occur until the LED switches off (becomes open circuit).
    I've had new LEDs that seem to oscillate - would be on for a 1/4 second, then off for a second. It was a new diode and I just replaced it with another.
    The LEDs are fairly cheap... What do you have to lose by replacing it?
    I get what you're saying, and I will try swapping in a new LED. Its just not triggering the open led fault of the controller that's bugging me and making me think the fault is elsewhere. Even leaving the LEDs unplugged doesn't even trigger the open led fault:/
    For testing purposes does the replacement LED have to be identical? I've got a spare (definitely working) strip out of a different TV that I can pull some LEDs off to swap over, would they do to indicate if it is that led?
  • SLK001
    replied
  • rockit711
    replied
    Tried different angles etc and it seems that it definitely turns off a frame or two earlier than the rest.
    If that is the cause I still don't know why the led open/short fault hasn't triggered though. It seems extremely odd to me that the chip would keep driving the transistors etc even after such a "fault"?? Also if this were the cause why would it drive the VFB pin low? Isn't that in essence trying to pull even more power out of the primary side controller (and hence triggering that controllers power-limiting shutdown)?
  • rockit711
    replied
    I just had the multimeter on current setting in series with the batteries and led being tested.
  • SLK001
    replied
    I just used some fresh AA batteries and the LEDs were drawing ~100mA, I assume the two I used a month ago were old. Doesn't that achieve the same thing? they each work fine with the 2AAs so I suspect if they are failing its higher than 100mA
    Should be the same thing. How were you measuring current?
    As for your movie, make sure that that your observation isn't a camera scanning artifact, by taking several movies with the camera at 0, 90, 180 and 270 degrees to the TV. If the same LED goes off early, then that guy is probably your culprit.
  • rockit711
    replied
    Set the power supply for 100mA MAX, then set the voltage to 5V. Use this setting to test the individual LEDs (or individual strips, if the voltage can go high enough). With the current limited, the voltage will drop to the voltage needed to force 100mA through the LEDs.
  • rockit711
    replied
    I took a movie of the LEDs flashing to see if any didn't turn on or were noticeably dimmer etc.
    the only irregularity that I caught was one of the LEDs seems to "turn off" faster than the others. (picture below)
    Is it likely/possible that this LED is the culprit? the rest take an extra frame to turn off (the entire bright pulse and fade out is 4 or so frames)
    Although if this is the case I still don't know why the fault pin isn't being tripped as surely that would engage the SCP and pull the fault pin low.
    I was also thinking, seeing as each of the LEDs can handle ~100mA through the AA battery test, is there any way to lower the output current limit just to test if the PSU actually brings them on (which would confirm a faulty LED at higher current)?
  • SLK001
    replied
    what do you mean? do you mean an external power supply or to somehow get the LED+ rail going and use that to drive it?
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • shahnld
    Lenovo legion 5 pro startup issue
    by shahnld
    Good day Experts
    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
    08-24-2025, 12:31 PM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
  • elmark
    HP 15-cw1002ua strange keyboard issue
    by elmark
    HP Pavilion 15-CW1002UA
    S/N 5CD0251CBC
    P/N 7KE54EA
    Hello guys!
    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
    It powers on OK and has no other issues except the following:
    • CAPS LOCK does not work at all
    • Fn button toggles Flight Mode
    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
    • (with SHIFT pressed: 't%' and 'y^' respectively)
    I initially thought it was a keyboard malfunction (internal short, etc.),
    but when I press and hold...
    06-27-2025, 01:10 AM
