Lnt5271fx/xaa
  • fxdfireman
    • Nov 2010
    • 86
    Lnt5271fx/xaa
    I got a Samsung LNT5271FX/XAA from a friend. When i got it it was dead no power, on stand by light. I looked over the boards and in my newbie thinking figured that the power supply failed and took out the main board. I ordered and replaced the power supply and main board and it worked when i turned it on. I turned it off and when i tried to turn it on again it would not do anything. Now it is like before no standby light. It does have 5V going to the main so i don't think its the power supply but what else would cause the main to go again?
    Thanks for any help!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lnt5271fx/xaa
    Can you provide a list of the legends alongside the connector pins and what the voltages are?
    • fxdfireman
      • Nov 2010
      • 86
      Re: Lnt5271fx/xaa
      OK Will get them after work.
      • fxdfireman
        • Nov 2010
        • 86
        Re: Lnt5271fx/xaa
        Here are the voltages and pictures. thanks for taking a look. Sorry it took so long to get back.
        1 - 0.039
        2 - 0.039
        3 - 5.191
        4-12 - 0
        13-16 - 0.039
        17-18 - 0
        19 - 0.370
        20 - 0
        21 -0.370
        22 - 0.374
        23-24 - 0
          Re: Lnt5271fx/xaa
          It would be nice if you had put the pin names for each pin.
          Right now the main board is not sending the PS-ON signal (Pin 1) to turn on the rest of the the power supplies.
          Try disconnecting the cable between the main board and the FRC board (the board between the main board and the T-CON board) to see what happen.
          May be your new board is bad too.
          • fxdfireman
            • Nov 2010
            • 86
            Re: Lnt5271fx/xaa
            It seemed to work initially. I am thinking that whatever caused the first board to be bad caused the second to fail also.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Re: Lnt5271fx/xaa
              Disconnect the power supply from the main AV baord and connect a 1K resistor between pin1 (Power On/Off) to pin 3 (STB5.2V) and check that all the other supplies come up.
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • shovenose
                Christmas Light Power Supply Question
                by shovenose
                I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                12-08-2023, 09:59 AM
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
