Vizio E37OVA hdmi ports no signals
  • AcGeorgiegirl
    • Jun 2013
    • 202
    Hey y'all. This Vizio was working fine, then each hdmi port stopped getting signals. Otherwise, everything works great. I've searched for general hdmi port troubleshooting, and only find things related to power-cycling, resetting to factory, etc, but this isn't fixing it. I've tested 3 different hdmi cables and 3 different devices....all of which do work fine on another tv of mine. I came to info that calls for me to understand/know how to trace to components for testing them, but I don't have enough details for my skill level, and thought I'd ask you guys for help. I see no physical damage to chips surrounding the ports. I don't know how to test for voltage going to the ports, and assume this may be a start?
  • mmartell
    • Oct 2013
    • 3189
    Re: Vizio E37OVA hdmi ports no signals
    You can test the regulators on the main board for proper voltage. Put your finger on the chip in the center of the third image, that's the chip responsible for the hdmi ports. It may need to be replaced.
    • charis
      • Mar 2016
      • 61
      • greece
      From what i see in the photo they using one HDMI chip.All the big brands like lg or samsung have separate hdmi ic for each port.When the 5v due to short in cable or to input device blow an hdmi the others keep work.
      In your set this dont happen.
      Check FB 503-504-502-506 and the 2 resistors near.Also near CN506 you have a resistor with a zero on it.
      On pin 18 in HDMI port(first down left as we look from the front) you must have 5v all times.
      • AcGeorgiegirl
        • Jun 2013
        • 202
        Thanks, guys!
        I know what the resistors are/how to test them, but don't know what "FB"s are...not that I didn't find them, but just don't know what the acronym stands for, and so I can't research how to test them(or, did you mention them only to indicate which resistors to test, nearby each?).
          FB = Ferrite bead which is basically a very small inductor, it should show as very LOW OHM (<1 Ohm).
          https://cdn.badcaps-static.com/pdfs/...99c6d4dd39.pdf
          http://www.murata.com/en-us/products...en-20110614-p1
          http://www.radio-electronics.com/inf...-inductors.php
          • AcGeorgiegirl
            • Jun 2013
            • 202
            Thanks, BUDM
            Weird, I couldn't find this info. I gave up too soon!
            • AcGeorgiegirl
              • Jun 2013
              • 202
              How do I test the resistors on my board? They are so small, no codes are seen, and I can't calculate what the resistance should be. I understand that a totally blown one will have infinite resistance reading, etc.
              • AcGeorgiegirl
                • Jun 2013
                • 202
                Pin # 18 on the 1st hdmi port(far left) had no voltage, both in standby and powered on.
                The FB's:
                504 .4
                501 .4
                502 .7
                503 .3
                The Resistors:
                at FB504 30.8 & 31.6
                at FB501 47 & 47.6
                at FB502 46.6 & 47.7
                at FB503 47.1 & 47.8
                • mmartell
                  • Oct 2013
                  • 3189
                  Is the chip heating up ? Might have to be replaced.
                  • AcGeorgiegirl
                    • Jun 2013
                    • 202
                    Do you mean does it get warm when the power is on? It's warm to the touch. Would the pin#18 not having voltage mean the chip is bad?
                    • mmartell
                      • Oct 2013
                      • 3189
                      Trace pin 18 to see if it goes back to the ic. If it does then check the datasheet for the ic to see what voltages it should have and measure to see if they are present.
                      If the ic is responsible for powering the ports and it is receiving voltage then it has likely failed.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Data sheet:
                        I think Pins 9, 27, 38, 64 should all be at 3.3V which are probably the 4 supplies for each of the 4 internal HDMI controller ports.
                        • AcGeorgiegirl
                          • Jun 2013
                          • 202
                          I'm getting around to testing them today. Just wondering...the data sheet diagram lists pins 50-51 as "HDMI control signals". What are these?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            There are 4 HDMI inputs so it could be to switch between HDMI1,2,3 and 4 using two data lines but this is purely guesswork.
                            • AcGeorgiegirl
                              • Jun 2013
                              • 202
                              These pins 9, 27, and 64 measure 0.13 each. Pin 38 measures 0.5...I'm assuming the chip is damaged/gotta replace?
                              • AcGeorgiegirl
                                • Jun 2013
                                • 202
                                In the datasheet you've linked, the diagram of the ic gives ids of each pin number but no voltage info. Did I miss something?
                                • AcGeorgiegirl
                                  • Jun 2013
                                  • 202
                                  Guys, If the ic isn't sending correct voltage only to the hdmi ports(everything else works just fine on the tv), is there any other component that I should be checking for damage/failure? IE...what could cause only the hdmi voltage to go haywire?
                                  • grimacelord
                                    Samsung UN50MU6070FXZA - HDMI Ports Not Working
                                    by grimacelord
                                    Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
                                    I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
                                    Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
                                    Since the HDMI controller appears...
                                    11-03-2021, 03:10 PM
                                  • DynaxSC
                                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                    by DynaxSC
                                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                    03-10-2025, 12:27 PM
                                    Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-06-2024, 09:40 AM
