(SOLVED) - RCA L32HD31R - Powers on, no picture
  • JDC
    • May 2015
    • 273
    Issue: Unit turns on w/ a blue light as indicator but has no picture.
    Solution: replace the two blown 1000uF 35V caps on power board.
  • csmith
    Vizio D50u-D1 Powers up no picture
    by csmith
    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
    issue. Set will power up with remote but not power off....
    07-11-2025, 11:52 AM
  • sergio_av
    Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
    by sergio_av
    Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
    Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
    When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
    Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
    01-01-2025, 05:27 PM
  • KYBOSH
    Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
    by KYBOSH
    Saved this beast from the landfill this weekend.
    Manfactured July 2013 in Mexico.
    I love working on plasma TVs.
    Its been a while but I was lucky enough to find 2 this week.
    The TV powers on and stays on but no picture. Havent checked for sound yet.
    No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
    Will start troubleshooting tonight.
    10-17-2024, 01:17 PM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
