TC-P58S2 10 Blinks
+ More Options
Posts
  • zdsh07p9
    • Nov 2013
    • 155
    TC-P58S2 10 Blinks
    Have looked around a little and see 7 and 1 blink posts but I have not seen a 10 blink post. Can someone give me some information? I turn the TV on with the power button on the side of the TV on the main board and it gives me 10 blinks - I tested some power and did not get power to the ysus. Really all ive tested so far. Does anyone know what the 10 blink code means?
    Thanks in advance,
    Z
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: TC-P58S2 10 Blinks
    Can you post clear shots of the back of the TV so we could see the boards lay out. Also do you know how to self-test the PWR board? We would need clear shots of the PWR board with the jack to the Main board visible enough to read each pin label.
    • zdsh07p9
      • Nov 2013
      • 155
      Will get some when I get to the house, Thanks. I do not know how to do a power board self test, but I have a multimeter and have worked on TV's for 10 years so I can learn
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You would also need a pair of 120Vac 100W light bulbs connected in series.
        • zdsh07p9
          • Nov 2013
          • 155
          Can you show me a picture of this setup? Because I dont have one currently haha
          • tw2005
            • Oct 2011
            • 6458
            10 blinks can be any board SC,A,SD,SS,SU,P,K.
            Shorted SC is a common one for 10 & 4 blink.
            probably a few ways to skin this cat but a favourite of mine is to isolate all the boards except P & A.
            If you disconnect, SC2,SS11,P35,3 white ribbons at the A-board, turn it on and see if it 10 blinks or turns on and stays on. Only run it for less than 30 secs if left it could shutdown as 4 blink.
            Don't reconnect sc2,ss11 p35 straight after as there'll be residual voltage. either check first or leave for 5-10mins.
            If it does not error then the 10 blink is not P or A and I would check the SC board for shorts or low ohms at SC2 or check Q661 as generally if the SC has failed that will be shorted.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • SentraDude
              (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
              by SentraDude
              Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
              I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
              Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
              04-04-2023, 04:24 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • DynaxSC
              Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
              by DynaxSC
              I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
              I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
              Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
              Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
              05-04-2025, 12:08 PM
