eax64905001 No Pfc Help ?
+ More Options
Latest Activity
  • CostasCostas
    replied
    Re: eax64905001 No Pfc Help ?
    Hi guys, I have this PSU with a 3 to 4 year old 32" LG TV. A few days ago the good wife splashed water on the TV, near the IR sensor, and now we just have sound and no picture.
    Trawling the internet suggests it might be a problem with the t-con board. I have checked the voltage readings on the psu and they seem to tie up with what's in this thread. I should just add that the LED's are coming on, just no picture.
    For the t-con board I have checked against the published voltage points and they look ok. Can't find any details or check points on the main video board.
    Do you think it will be the t-con that has failed or are there any basic tests I can do on the video board?
  • Guest
    Guest replied
    Originally posted by gurug
    Problem SOLVED!
    It was two LED's which were broken on backlight ... power supply does not output 70V if it detects problem with LED's ... So it was in protective mode. I replaced LED's and TV is working normally. Thanks for you help and ideas!
    Did you replaced the entire led stripe or just the single leds? in the second case can you tell me the led's identification code?
  • jarda105
    replied
    One more thing is after cca 10minutes of measuring is hard to touch heatsink on Q101 because of temp I think about 60°C.
  • jarda105
    replied
    Please for advice. Voltage on P801 - led output is between 0 - 0.6V (oscilating). TV is operating (with headlamp directed on LCD panel I can see MENU). Testpoints P802 (43-45V), P803 same. P203 11.9V, P202 23.3V, P204 23.3V
    Q801 - DRAIN 44V source and gate 0V
    Q802 - DRAIN 0.130V source and gate 0.020V
    Main voltages are 3.45V, 23.4V, 12V, on con. to Mainboard PDIN 1.12V and DRVON is 3,0V
    On IC801 pin 9 PWMO (to Q802) is 0,02V. Vcc is 12V and REF is 4,96V. But gate pin 3 is only 0,02V. Thank you for any advice. What voltage should be on IC801 on pin 9? On schematic is Q803 but I can't find it on board - probabaly it's different version.
  • jarda105
    replied
    Thank you, I'll do some measurements.
  • ReeceyBurger123
    replied
    It should at start up with the Leds out fire up to 80v then back to 24v if there are no Leds if not then the Leds are fine and Psu is at fault.
  • jarda105
    replied
    Hi, I have similiar problem with EAX64905001. I have no output voltage on con P801 with unconnected LED panel. Is there any protective when there's not load on output ? Or should be there 80V ? Thank you.
  • ReeceyBurger123
    replied
    Nice work
  • gurug
    replied
    Problem SOLVED!
  • gurug
    replied
    Tested q801 and it seems ok ... hm, I guess I'll just order new power supply
    Hm, order "new" power supply board, but no luck ... seems this board I got is broken too ... It has 0V on LED output ... but I'm wondering, it is same model of board EAX64905001, but original was REV2.0 and this one I bought via eBay is REV4.0... Is this relevant?
    Like I said before on old board when I disconnect MOSfet I got stable 46V on connector ... please advice me further where to look - mosfet seems ok ...
  • gurug
    replied
    I disconnected mosfet q801, and i got 46V on led connector and no fluctuation... does that mean that q801 is bad?
  • gurug
    replied
  • gurug
    replied
    Originally posted by ReeceyBurger123
    Q801 matey, I have a video on this set being uploaded next week of how I repaired it.
    I thought your problem was only with MAP3202?
    On mosfet middle pin gets 43 to 48V - from L801
  • ReeceyBurger123
    replied
  • gurug
    replied
    Ahh yes I see my bad I got confused with the other cap. What VCC is going to the mosfet ?
    Can you tell me which mosfet you have in mind?
  • ReeceyBurger123
    replied
  • gurug
    replied
    Yes on connector is from 11 to 20V. And on C214 is like I said. And it's not going straight to connector, see attached schematics.
    I'm measuring C214 directly and LED connector also directly I use + and minus on connector...
  • gurug
    replied
    So on the connector its 0-20v then on the cap which is the Led output filter its 48v ? I dont see how you measured this as the cap goes straight to the connector ? Seems to me like the controller is still bad, or something that feeds it is bad.
  • ReeceyBurger123
    replied
  • gurug
    replied
    PCB is same as listed on first page of this thread, I attached pictures. And also schematics of power supply.
    On C204 and C214 voltage is fluctoating from 43 to 48V ... if this helps to diagnose?
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • THE GTC
    Insignia NS-37D20SNA14 intermittent LEDs
    by THE GTC
    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
    11-03-2020, 02:40 AM
  • VitalComputing
    Replacing Mode Indicator LEDs
    by VitalComputing
    I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
    I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
    I thought I could just put a resistor...
    09-17-2023, 04:43 PM
  • jimbofz
    just a quick question do all qled leds appear blue when fault finding ?
    by jimbofz
    i have replaced many leds strips that have changed blue when they are worn
    and the new replacements are perfect white
    but when fault finding do quantum leds always look blue?
    08-28-2024, 06:51 AM
  • Quantum IC
    LEDs for TV Backligth
    by Quantum IC
    Hello everyone
    I'm new to LED strip LED replacement.
    The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
    I understand that this is due to the tone of the light they emit.
    My Doubt is:
    Can I use the LED with two internal chips without problem?
    Will there be much difference in the picture?
    I'm going to replace all the LEDs.
    Both LEDs (original and replacement) are 3V and the same size....
    03-04-2022, 04:03 PM
