Sharp Aquos Quattron 60 3d TV LC-60LE835U
  • topfli8979
    • Oct 2012
    • 311
    Picked up a Sharp 60" LED tv with a static vertical line. I know its a panel issue. I went ahead and diassembled down to the panel to look at the tabs. No amount of pressure on any of the tabs will take the green vertical line out. Would it be a more in depth problem with the make up of the panel? Not the normal tab bonding issue...
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Sharp Aquos Quattron 60 3d TV LC-60LE835U
    Could be the COF chip itself, its bond to the tab, the panel or the tab itself. All rather academic--as you've proved in this case it cant be cured....
    TELEFIX
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
    • sefoster
      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
      by sefoster
      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
      11-20-2022, 09:29 AM
    • jonah1024
      Sharp Aquos LC-40UG7252E LCD TV burn in?
      by jonah1024
      Hello!
      I'm a few days old into this TV screens repair universe so please bear with me.
      Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
      - I did the classic unplug and hold power button to discharge the caps but it didn't help.
      - I did a factory reset as well...
      07-16-2024, 04:23 AM
    • klassic
      Sharp Aquos LC-60LE635E three blinks
      by klassic
      Hi community,
      I will describe my problem with a TV in those short following terms to be the most precise :
      What i have :
      power board DPS-162KP-1
      main logic board QPWBXF733WJN2
      symptoms :
      white led light logo at startup,
      after 2 minutes, blinking 3 times a row, repeating
      no backlight (and apparently no picture, checked panel with flashlight)
      no startup sound
      powerboard investigations :
      1-2 PNL : 0v
      3-4 GND
      5-6-7-8 UR : 13.15v
      9-10-11-12...
      10-24-2023, 01:39 PM
    • Joekhoe
      Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
      by Joekhoe
      Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
      I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
      The replacement as follows:
      1. IC7905 : TNY264PN (first found exploded)
      2. Q7915 : BT169D (exploded too)
      3. IC7901 : 1608B (controller ic)
      4. IC7601 :...
      09-17-2020, 05:52 AM
