Coby LEDTV4028 and LEDTV5028
  • jstiene
    • Feb 2013
    • 148
    Hello. I have each of these Coby TV's sitting here, brand new, dead. 40" doesn't power up, and the 50" will work periodically. No parts seem to be available. What I was wondering is (1) has anyone else worked on this with any experience as to what their typical problems are, and (2) are these parts used in other brand TV's? Trying to determine the effort I should put into these...
    Joe
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: Coby LEDTV4028 and LEDTV5028
    Joe
    first check the power supply voltages the out put voltage..... check if theres 5v standby
    • hmendez86
      • Jun 2015
      • 344
      • united states
      post pics of the power and main board.....
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8148
        ... and a much better description on what the TV does or doesn't do. Is the LED on etc?
        • Mark D
          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
          by Mark D
          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
          10-29-2024, 03:15 PM
        • 2elw
          SVOD4 PCB pictures + parts
          by 2elw
          Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
          STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
          GW1N-UV9UG169C6/I5 FPGA - Its a...
          07-04-2025, 12:23 PM
        • SurrealMustard
          What parts can be salvaged from a plasma with a damaged display panel?
          by SurrealMustard
          I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
          03-09-2025, 08:29 PM
        • DynaxSC
          Asus Rog Strix B360-I Gaming - Parts Identification
          by DynaxSC
          I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
          I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
          Thanks in advance...
          08-23-2023, 07:56 AM
        • lorins_core
          BQ24800 to can it be replaced with these parts BQ24780S
          by lorins_core
          Hello to all.
          may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
          I need some good advice and also some information about it. thank you and God Bless...
          05-10-2024, 07:56 PM
