What part do i need for this? See a white blank strip. Are these the buffers gone bad?
Needin diagnosis of vertical lines for my potentially new project PN64E533D2F
Re: Needin diagnosis of vertical lines for my potentially new project PN64E533D2F
Failed Panel, the COF address driver which is bonded to the panel has shorted out not replaceable.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
BUT......You can sell the power supply for good money!!!! They are super hard to get.Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/Comment
Vertical stripes or lines are never good news on any flat-screen TV, usually indicating panel or integral driver-chip failure...
Free advice--Never buy Any s/h faulty set--Unless you need its parts--if it has Any vertical lines....TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Thanks, ill weigh the options. I had gotten a samsung 55ln550c on a good deal. It had pinkish vertical lines about every inch across the whole screen. I simply eliminated the screw that goes from the cover through and into the main board. Then used a larger winged bolt to screw through the sheet metal cover but too big to fit into board, causing tension and twisted until lines went away. BTW i hate 4d tv.Comment
ah... but regular vertical lines isn't usually a panel problem. A panel problem is usually "area centric" as opposed to across the screen. As you have found, the main board can produce "whole panel visual issues" that can be recovered from.Comment
highly unlikely that people have been successful with tab bond "remakes". You can try putting some thermal padding on one of the pads to see if it helps in terms of pressure and also heat conductivity... some people have had some success in that direction but it is usually limited and usually with lcd based screens.Last edited by budwich; 04-14-2016, 05:21 PM.Comment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by angelosHi Guys.
I have experienced something rather unique and need to find out by the forum what to make of it.
I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal... -
by sam_sam_samRight now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
https://batteryhookup.com/products/3...ttery-with-bms
These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue... -
by BladibladI have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's... -
by EasyGoing1So based on some of the comments in my other posts, there seems to be some confusion or maybe some assumptions, I'm not sure exactly, so I wanted to hit the reset button on the entire discussion and make a few things clear that might not have otherwise been obvious.
First of all, the reason I post in this forum is that I simply do not have enough knowledge in electronics to do some things that I would like to do. So I post my questions in here and I try to be as thorough as possible MOST of the time, so that those of you who do take the time to respond, will be as informed as possible... - Loading...
