Samsung LN46D630M3F, TV powers on, sound works but no backlight
  • Five_magics
    • Apr 2016
    • 47
    Re: Samsung LN46D630M3F, TV powers on, sound works but no backlight
    The IC appears to be a FAN7930B.
    On which pin would I measure the PS_on signal? Im guessing ZCD.
    I take voltage measurements when the set is turned on.
      Tracing out the board, pin 8 is the switched VCC pin which gets the VCC through a switched Transistor QM804 (turned on by OPTO PCM802, PCM802 is turned on by the PS-ON) from the AUX winding of the STBY transformer.
      So check the VCC on pin 8 with ref to the negative leg of the main filter cap when you turn on the TV and PS-ON is present.
      Pictures provided by shopjimmy.
        CN802 pin 18 per chart printed on the board.
        The exposed pins of the CN802 as you can see from the top are the ODD NUMBER PINS.
        • Five_magics
          • Apr 2016
          • 47
          Oh yeah ok I thought you meant on the IC itself, will report back.
            FAN7930B spec.
            So I am correct based on board tracing that pin 8 is the VCC pin.
            • Five_magics
              • Apr 2016
              • 47
              PS_on=4,9vdc
              ICP801's VCC=12,9vdc
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8347
                So the PFC controller has enough voltage to be enabled.
                • Five_magics
                  • Apr 2016
                  • 47
                  So I'm guessing either the PFC circuit is faulty somehow, or there's some sort of feedback and it's in protect-mode?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8347
                    Again, how much voltage is on the main filter cap when the tv is on? Measure both leads directly on the cap. Should be more than 360v DC.
                    • Five_magics
                      • Apr 2016
                      • 47
                      160vdc
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8347
                        When the tv is turned on?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8347
                          160v DC is just rectified mains, so either the tv is off, or the PFC (booster circuit) isn't working.
                          • Five_magics
                            • Apr 2016
                            • 47
                            You actually made me doubt, but the TV is indeed on. Still 160vdc on main caps.
                            Funny part is, this time, the backlight actually lit up for a few seconds before shutting down. Last thing I did was take measurements (check-diode) in the PFC circuit. Faulty PFC? Thought it could be a bad contact so I tried tapping the board near the PFC but no dice.
                            Or can a faulty CCFL/inverter shutdown the PFC circuit?
                              You can disable the bl-on signal by grounding the bl-on pin. With 100 Ohms resistor to Gnd to see if the PFC will come up and stay up.
                              Btw, all these time we thought the backlights never did come on per post 3.
                              • Five_magics
                                • Apr 2016
                                • 47
                                It didn't come on until just now. By "this time" I meant like an hour ago :O. Used check-diode in the PFC circuit, tested the set again to take measurements and to my surprise it came on for a few seconds, which makes me think I charged a capacitor/FET making it work for a brief time -> bad ICP801?
                                Will try shorting the BL_on signal tomorrow at work (again, lack of equipements/components).
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8347
                                  Well... if the backlight came on for a brief second, that is a big game changer.
                                  • Five_magics
                                    • Apr 2016
                                    • 47
                                    Didn't have much time over the weekend, but tonight I shorted BL_on to the ground via the 100 ohm resistor, and the PFC circuit comes on (around 450vdc on main caps).
                                      And it stays at that level? If it is really 450VDC between the two legs of the cap then the PFC circuit should shutdown, it has protection not to let the output Voltage goes way beyond 400V. I hope your meter is accurate.
                                      if you look at the spec sheet of the IC, there is explanation on how the IC works including the OVP (Over Voltage Protection), There are two strings of Voltage divider resistor networks for sensing function.
                                      If you look at the bottom side of the board, you will see two set of resistors, each set has a bunch of resistors connected in series to form Voltage divider and feed the IC pins per the spec sheet. so it can be that the value of the resistors have changed so it caused the output Voltage to go too high, I would check out those resistors.
                                      • Five_magics
                                        • Apr 2016
                                        • 47
                                        Meter probably isn't that great, cost me 35$, Mastercraft brand. Will see if I can borrow a Fluke/BK precision from work, just in case.
                                        Initially it measures at 430vdc~, goes up slowly in 1 volts increments. When it reached 450vdc I shut the TV off, because with caps rated at 450 volts... yeah.
                                        I have seen the divider you're talking about. Will check it out and report.
                                        EDIT: Just checked the resistors and I think the meter is crap. The resistors measure somewhat okay in a direction(1,05M instead of 1,2M), but when I reverse the polarity it drops to 800k or so. Will check it out with a Fluke tomorrow.
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8347
                                          Most of the time the batts are low when the meter shows crap measurements. If you have the biggest MasterCrap DMM that you got on sale for $30, that is actually the best cheapy and decent for the money.
                                            09-07-2024, 05:50 AM
                                          • ex250
                                            Kenwood SW-505D no sound issue and pops from time to time when it works
                                            by ex250
                                            Hello mates,
                                            I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                            It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                            12-29-2024, 03:27 PM
                                          • nosaj
                                            Samsung QN82Q70RA powers on then powers off
                                            by nosaj
                                            I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
                                            So I thought I'd just quit messing around and come to the best site...
                                            11-07-2025, 04:58 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
