Samsung LN46D630M3F, TV powers on, sound works but no backlight
    Re: Samsung LN46D630M3F, TV powers on, sound works but no backlight
    As you can see, the circuit is very sensitive (Triming the 38.8K with 2M resistor) and they set the output Voltage by trimming the Total resistance of two resistors, so as long as you get the output Voltage to be around 380~390V range then you will be OK, i would try to get the resistance toward higher Value than lower value. What is the next up value of 38K 1% available at digikey?
    • Five_magics
      • Apr 2016
      • 47
      As a single resistor, there are 38,3k 1% available. If I use resistors in parallel I can go with 56,2k with a 118k for a total of 38 068 ohm.
        You can try both setup and see.
        • Five_magics
          • Apr 2016
          • 47
          Ordered everything (the caps, the resistors and the IC). Will report back whenever I receive everything.
          • smuddge
            • Feb 2012
            • 96
            did anyone get to the bottom of this? I have the same problem as the original poster. just would like to know what I need to order to fix it.
            • Flip_ep
              • Feb 2017
              Any update on this havin the same problem. Picture sound good just no backlight. Inverter is good.
              • Flip_ep
                • Feb 2017
                Resoldring the joints fixed my problem. For backlight now working tv good so far.
                • Louis82
                  • Feb 2012
                  • 240
                  Resoldering bad connections has worked only for a few days. Problem is back again. Any update in regards the solution for this.
                    09-07-2024, 05:50 AM
                  • ex250
                    Kenwood SW-505D no sound issue and pops from time to time when it works
                    by ex250
                    Hello mates,
                    I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                    It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                    12-29-2024, 03:27 PM
                  • nosaj
                    Samsung QN82Q70RA powers on then powers off
                    by nosaj
                    I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
                    So I thought I'd just quit messing around and come to the best site...
                    11-07-2025, 04:58 PM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • jchang
                    Samsung UN70NU6900F no picture and no sound
                    by jchang
                    Hi all
                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                    Symptom:
                    No picture no sound.
                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                    No sound at all.
                    What I tried:
                    1. I tried unplugging the left or right ribbon...
                    01-09-2023, 06:28 PM
