Problem updating Samsung PN51D550C1F with USB
  • tech2014
    • Aug 2014
    • 807
    I try and update to the latest firmware and it says there is no file found to update. I also cannot download anything online either. I took a pic of the screen which shows the latest version. Is this the latest version? If not, why won't it let me update.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Problem updating Samsung PN51D550C1F with USB
    Is this it?
    http://www.samsung.com/ca/support/model/PN51D550C1FXZC
    • tech2014
      • Aug 2014
      • 807
      yes. I just read something in the file on my USB, it says 1018, my tv says 1019 so must be the newest one then??
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What you say sound correct but it's just a bit odd that Samsung would leave an older update on their site.
        • budwich
          • Jul 2015
          • 3097
          why do you want to update your firmware?? How old is the TV?
          • tech2014
            • Aug 2014
            • 807
            I was told that the new firmware will prevent the XSUS board from shorting out again. Something about over voltage on the panel and the new firmware fixes this problem.
            • budwich
              • Jul 2015
              • 3097
              So you lost a XSUS board and someone indicated that there is a software fix to potentially stop that? How old is the TV? Has it ever been updated? From my limited Samsung experience, "versioning" on their sets isn't "obvious" sometimes and sets may ship with different versions than what appears on their site for what ever reason. I wouldn't load a different version into your unless you are having an obvious problem.
              • Kjell
                Samsung Series 9 - BIOS issue
                by Kjell
                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                08-01-2025, 09:15 AM
              • Eotis
                Framework 13 laptop ,Nvram locked ,TPM issue
                by Eotis
                Hi folks. I have a Framework 13 laptop with these specs.
                Motherboard: Framework FRANBMCPOC AC
                Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
                Graphics: Intel Iris xe
                Installed RAM: 64.0 GB (63.8 GB usable)
                System type: 64-bit operating system, x64-based processor
                Bios: Uefi InsydeH20 3.24
                Edition: Windows 11 Pro/ AtlasOS
                Version: 23H2
                Installed: ‎9/‎16/‎2024
                OS build: 22631.4169
                Intel Chipset driver: 10.1.19502.8391
                This processor seems to...
                Yesterday, 08:55 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
                09-07-2024, 05:50 AM
              • jeffer dacon
                latest ME region BIOS update hp 440 g3
                by jeffer dacon
                Hi guys, could you update the ME region of this HP 440 G3 BIOS? I have cleared the Me region but it still doesn't work, thanks
                11-26-2024, 12:14 PM
