Telefunken T32TX182DLBP NO Turn on - Blinking LED
  • vinceroger69
    replied
    Re: Telefunken T32TX182DLBP NO Turn on - Blinking LED
    Originally posted by nikgegr
    can you link the video again i can find it
    https://www.youtube.com/watch?v=kPCisa9BYkk&t=8s
  • nikgegr
    replied
    Originally posted by ReeceyBurger123
    You need to find the core update file on the internet then reflash that. Guessing you didnt watch all the video as it shows me doing that
  • dskall
    replied
    I've read several places that say the eeprom data gets corrupted but seldom does the eeprom fail. If that's true then why can freezing get them to work at times.
  • vinceroger69
    replied
    i didnt know eeproms had life cycles can we buy ones with longer hours?
  • dick_barton
    replied
    So i've heard. It's a pity that the EEPROMs in use are so unreliable supposedly having 100,000hrs plus lifetime.
  • vinceroger69
    replied
    Originally posted by dick_barton
    Vinceroger69 Is this what you want?
    Thanks dick_barton i will give it a try vestel have changed that site reece mentions in his video a lot of firmware they are charging for now ive been told.
  • dick_barton
    replied
  • vinceroger69
    replied
    Originally posted by GeorgeVasil
    m8!
    The TV works AGAIN! Thanks for the support!
    I want to ask you something else:
    I got some replacement diodes on Saturday from a local store because i was in a hurry.
    Is it OK to replace the 5404 x2 and 1x 5402 with some 5408's? (The shop owner told me that i won't have a problem..he didn't have 5404/5402 available).
    Is there anything else to change on the PSU, in order to protect the tv from failing again?
    Have you still got a copy of the core update file you could upload please as the vestel site is now charging for the download
  • ReeceyBurger123
    replied
    Good stuff
  • GeorgeVasil
    replied
    Also one last thing now that you have done the firmware you need to first time install the Tv and turn the backlight down to low if not an Led will burn out in no time flat lol
    Yes I have already done that, as mentioned to your video.
  • ReeceyBurger123
    replied
  • ReeceyBurger123
    replied
    m8!
    Awesomeness glad to hear it worked Also yes they will work fine they have a higher current and reverse voltage so they might actually hold out for longer. Also nothing else really to change on these apart from the diodes
  • GeorgeVasil
    replied
    Ok mate, the buzz is normally poor standby oscillation when the Led goes on it loads the standby power a little then off it becomes unloaded but because the feedback is poor so you can hear the transformer switching to supply the standby Led when it goes on lol its normal for Vestel sets though. Also you need to hold ok with the Usb with the core update plugged in it will take a few tries to get it going.
    m8!
  • Diah
    replied
    i dont care... i just write what i have on mind... buzz sound when he hearing, mean the the first Bit BOOT passed and PWB turn on. second BIT wont start.. as error.. .. this Firmware construction. eeprom, sip. or what ever you call will have only the first 8 BITS of standby boot firmware.. and he had it as hear buzz sound
  • ReeceyBurger123
    replied
    Originally posted by Diah
    buzz sound not related to Firmware. its much at Video Processing section , include LVDS. check or reset LVDS
    Nothing to do with the Lvds signal but poor standby power oscillation. You would know that up you read further up. Also dont cry about my reply not offending or slating you just correcting.
  • Diah
    replied
    i want to mention, is that i can hear a buzz sound every time
  • vinceroger69
    replied
    maybe freeze whichever chip it has either a eeprom/spi flash this sometimes makes the set start up ok then add the core update.
  • ReeceyBurger123
    replied
  • GeorgeVasil
    replied
    Thanks man! I am struggling to power on the TV again :/
    Another thing i want to mention, is that i can hear a buzz sound every time the LED blinks.
    I will post again about the results!!
  • ReeceyBurger123
    replied
    Link to core update:
    http://www.vesteldriver.com/TV_MB82_CORE_UPDATE.html
  • mar1in
    LG UH652T doesn't turn on and stands is blinking once a second
    by mar1in
    I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
    Did test the following:
    * LED's seem fine as they all light up using LED Tester
    * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
    * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
    * DRV_ON is doing the same
    * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
    * there is a tiny clicking...
    11-10-2024, 06:23 PM
  • jxrepman
    Asus X453MA won't turn on and green led light blinking
    by jxrepman
    Hi there,
    I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
    I have checked the charger and it is giving 19+ V
    I have disconnected the battery and pressed power button for 30 seconds.
    I tried another RAM stick.
    Tried disconnecting the keyboard and touchpad.
    Tried disconnecting the HDD and the wifi adapter.
    The problem persists.
    Hope you could help me out on this one. Thank you.
    12-14-2024, 06:40 AM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • zvvvpnrsa
    Telefunken D50U600M4CW does not turn on.
    by zvvvpnrsa
    Mainboard Vestel 17mb130s 23527519
    Panel VES500QNDC-2D-N15
    NAND Flash Memory 29F4G08ABAEA
    SPI Flash 25L1606E
    Hello everyone, I need help, there is a Telefunken D50U600M4CW with a problem that does not turn on, the duty LED is flashing red.
    All voltages are present on the power board, I tend to the version that the firmware has flown. I read the dump from SPI Flash 25L1606E, as I understand it, it is broken.
    Can anyone share a dump for SPI Flash 25L1606E or fix it, or if possible, is there a firmware for this model.
    11-28-2022, 04:39 AM
  • my dodge
    HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
    by my dodge
    Hello
    I was looking for a schematic or board view but unfortunately I didn't find anything.
    By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
    Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
    Please guide me.
    Thank you.​
    12-12-2024, 08:37 AM
