Telefunken T32TX182DLBP NO Turn on - Blinking LED
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Telefunken T32TX182DLBP NO Turn on - Blinking LED
    Originally posted by dick_barton
    Vinceroger69 Is this what you want?
    Thanks dick_barton i will give it a try vestel have changed that site reece mentions in his video a lot of firmware they are charging for now ive been told.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      So i've heard. It's a pity that the EEPROMs in use are so unreliable supposedly having 100,000hrs plus lifetime.
      • vinceroger69
        • Mar 2012
        • 6714
        i didnt know eeproms had life cycles can we buy ones with longer hours?
        • dskall
          • Oct 2016
          • 2905
          • usa
          I've read several places that say the eeprom data gets corrupted but seldom does the eeprom fail. If that's true then why can freezing get them to work at times.
          • nikgegr
            • Aug 2017
            • 3
            • greece
            Originally posted by ReeceyBurger123
            You need to find the core update file on the internet then reflash that. Guessing you didnt watch all the video as it shows me doing that
            can you link the video again i can find it
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              https://www.youtube.com/watch?v=kPCisa9BYkk&t=8s
              • mar1in
                LG UH652T doesn't turn on and stands is blinking once a second
                by mar1in
                I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
                Did test the following:
                * LED's seem fine as they all light up using LED Tester
                * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
                * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
                * DRV_ON is doing the same
                * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
                * there is a tiny clicking...
                11-10-2024, 06:23 PM
              • jxrepman
                Asus X453MA won't turn on and green led light blinking
                by jxrepman
                Hi there,
                I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                I have checked the charger and it is giving 19+ V
                I have disconnected the battery and pressed power button for 30 seconds.
                I tried another RAM stick.
                Tried disconnecting the keyboard and touchpad.
                Tried disconnecting the HDD and the wifi adapter.
                The problem persists.
                Hope you could help me out on this one. Thank you.
                12-14-2024, 06:40 AM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • zvvvpnrsa
                Telefunken D50U600M4CW does not turn on.
                by zvvvpnrsa
                Mainboard Vestel 17mb130s 23527519
                Panel VES500QNDC-2D-N15
                NAND Flash Memory 29F4G08ABAEA
                SPI Flash 25L1606E
                Hello everyone, I need help, there is a Telefunken D50U600M4CW with a problem that does not turn on, the duty LED is flashing red.
                All voltages are present on the power board, I tend to the version that the firmware has flown. I read the dump from SPI Flash 25L1606E, as I understand it, it is broken.
                Can anyone share a dump for SPI Flash 25L1606E or fix it, or if possible, is there a firmware for this model.
                11-28-2022, 04:39 AM
              • my dodge
                HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
                by my dodge
                Hello
                I was looking for a schematic or board view but unfortunately I didn't find anything.
                By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
                Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
                Please guide me.
                Thank you.​
                12-12-2024, 08:37 AM
