LG 55LW5700 Service Manual
    Having a problem with an LG 55LW5700-TA. It won't turn on. Showing a solid red led. Has anyone a service manual to diagnose the problem. I'm thinking the power supply is fine. Possibly a problem with another of the cards.
    Re: LG 55LW5700 Service Manual
    Wait until GET MANUAL appears!!!
    regards thoma
      regards thoma
      Thanks heaps mate.
      You wouldnt happen to know the diagnostic codes for the red standby light are?
        Ok. So I turn the tv on. Get a faint relay click, but the tv dosent turn on. All im getting is the red standby led slowly flashing and fading. it just does it over and over. I hit the power button again and the same thing. Faint relay click, then the flashing led.
        Any ideas?
          Anyone
          Had a look at the main board. Model LD12C EAX64405501 (0). Ran through the diagnostic as per the service manual. All voltages were normal. Though I couldn't access Q507 as it was on the back of the board.
          Before the screen blanked out. It went purple, flashed, came back to normal then blacked out.
            http://alpengeist-tvrepair.blogspot....-clicking.html
            Perhaps?I know other lcd-tv!
              Cheers mate. Cant help to try.
                Ok. So I have gone through the service manual and tested each output on the main board. Everything seems to be within spec. I'm getting power but no picture. So I guess it has something to do with the t-con board.
                I know the tcon is getting power via lvds from Q507 12v. It's measuring 12v at Q507 and L511.
                How do I test the tcon board. I can't find any schematics anywhere. The tcon board model is LG 6870C-0369C Ver 0.2 (2675E1).
                Anything else I'm missing.
                  So just to be sure, do you have backlights? and backlights are staying on after the flash?
                  Pictures of the boards to see what we are dealing with?
                    I turn the tv on via the switch. Hear the relay click. And nothing. A completely black screen. No light at all. The only light showing is a slowly flashing red standby light.
                      Well we need to see the board and especially around the power supply connectors so we can give you the test points to find out what are missing.
                        Main
                          Power
                            BTW, did you check out that inductor in that link? And able to force on the backlights and power supply?
                              Yeah mate. I'm getting 24v.
                                And backlights?
                                  So from p501 Pin 4 = 24.8v
                                  L504 to ground (both sides) = 24.8v
                                  Continuity either side of L504. And continuity from inlet side of L504 to L1801. Which is where it goes on the board.
                                    As for back lights. Looking at the panel front on is completely black.
                                      I'm not sure where to test on the board for the backlights.
                                        In the link thoma provided, it shows you how to get the backlights to come on using resistors, you can look at the front or the back of the panel to see if it has glowing lights in the darkened room.
                                        Right now we want to know if we have more than one board problem.
