Toshiba Vestel 22inch Dead, but not diodes
  • Fleckers tv
    Fleckers TV
    • Nov 2015
    • 89
    Bought this thinking it would be the usual failed Diodes but no, in fact all voltages seem ok, where else should I check please,
    I am getting
    11.34 v
    5.23v
    3.31v
    3.31v
    5.23v
    all other pins read zero
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Toshiba Vestel 22inch Dead, but not diodes
    maybe another case of bad firmware whats the mainboard part number.
    • Fleckers tv
      Fleckers TV
      • Nov 2015
      • 89
      Hi and thanks for replying 23148120 could bad firmware render the set dead, no stand by light etc ?
      • vinceroger69
        • Mar 2012
        • 6714
        maybe if it uses a 17MB95S-1 V.1 ive had a toshiba 32 in version with this fault a new mainboard solved it maybe wait and see what other peoples thoughts are.
        • Diah
          • Feb 2013
          • 6565
          is it Toshiba 22L1333B ??
          diagnose from vinceroger69 correct, its glitch at boot firmware,
          replace main board the last option if you don't flash boot Firmware.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            There is a tiny diode near the Lvds out put not sure on the Pn but check it for S/C and see if its shorted.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Its D164 see if its shorted out.
              • Fleckers tv
                Fleckers TV
                • Nov 2015
                • 89
                you mean this one, its reading fine...... sadly, looks like a new Main board , does anyone know if there is one going, nothing on ebay
                • vinceroger69
                  • Mar 2012
                  • 6714
                  you maybe able to get the firmware have you got any freeze spray as sometimes you can freeze the ic and the set will start if it does you can get a reader and copy the data to a new chip failing that some times you can get a pre programed ic from ohm supplies but wait and see what the other think as it maynot be a firmware issue!
                  maybe this will work but please confirm yourself as we havnt got the boards etc in front of us to comfirm
                  http://www.ohmsupplies.co.uk/epages/...=ViewAccessory
                  • Fleckers tv
                    Fleckers TV
                    • Nov 2015
                    • 89
                    good call, just froze the ic, it has given me the a green and red flashing standby light but not brought it on,
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok now you need to try and reload the firmware Via Usb. I will link it for you
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Follow this thread and get that firmware on as fast as before the Ic fails again:
                        https://www.badcaps.net/forum/showthread.php?t=52485
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Vince I have that exact kit linked on here mate for FREE
                          • Fleckers tv
                            Fleckers TV
                            • Nov 2015
                            • 89
                            Thanks chaps. The stand by continues to flash red green , no power up, will this reflash kick it in ?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Worth a shot, not going to cost you a thing any way
                              • Fleckers tv
                                Fleckers TV
                                • Nov 2015
                                • 89
                                Will do. May I have a link to the kit please , never done this before .
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  cheers for the link reece that will certainly help a few members out.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    reece has put it in post 3 in this link
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      No problem, I brought it to fix one I had then uploaded the files to here.
                                      • Fleckers tv
                                        Fleckers TV
                                        • Nov 2015
                                        • 89
                                        Most kind. Thanks Reece
                                        • lberkani
                                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                          by lberkani
                                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                          - Toshiba 65UL2163DG
                                          - Vestel 17MB180E mainboard
                                          - Panel VES650QNTX-N2-N42
                                          - Version V1.28.100.0 if available
                                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                          11-11-2025, 12:37 PM
                                          09-06-2024, 05:27 AM
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                          09-06-2024, 05:59 AM
