Philips LC420WUF-SAA1 resistor issue (I think)
+ More Options
Posts
  • ovrax
    Philips 55PUS6804/12 turn on & off (probably backlight issue)
    by ovrax
    First of all, please excuse me as I'm quite new to this field.
    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
    The Ambilight works perfectly and stays on.
    No sounds.
    Thanks in advance.
    08-25-2024, 04:33 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
  • charlesdutcher
    No picture issue in Philips Chassis FTL2.1
    by charlesdutcher
    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
    Is there someone having any symptom like this? How to fix it?
    Thanks in advance!​
    08-06-2024, 09:55 PM
