Panasonic TC-P50S30 7 Blinks
  • ultimatt
    • Apr 2015
    • 29
    So a neighbor just gave me this set with no picture and 7 blinks.
    Per the service manual it is a SC, SD or SU problem. or maybe all 3.
    I disconnected the SC ribbon cable and power connection and then turned the set on...with this configuration it was blinking 8 times (manual says SS board).
    The manual indicates that there is a LED on both the SC and SS board...I can find no lit LED's on either board.
    I looked it over and can't find any obvious damage...no blow caps, loose connections etc..
    With the no LED's could it be the power board?
    What would be the best way to isolate this problem?
    I will tackle the set with a multi meter tomorrow...thanks for the help.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Panasonic TC-P50S30 7 Blinks
    Do you have a multi meter? THese are notorious for blowing the sc board.
    If you measure the 2 pins at sc2,you will find them shorted.
    Repair kit:
    http://www.shopjimmy.com/panasonic-t...-tc-p50s30.htm
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • ultimatt
      • Apr 2015
      • 29
      No continuity between the 2 pins at SC2
      • tw2005
        • Oct 2011
        • 6458
        If sc2 is not shorted then I'd try the sd/su isolation test. Remove the 4 vfg gnd screws from the sd/su boards. Disconnect buffers from the sc board (3 white connectors). Then on the sc board jumper the 2 pins at sc50 and turn on tv see if it 7 blinks still. That will prove if sc is ok
        • ultimatt
          • Apr 2015
          • 29
          That is my next step...weird thing is I checked the buffer connectors for a SD or SU short to ground and could not find one..from past experience an IC short to ground has always been the problem in the past...
          • ultimatt
            • Apr 2015
            • 29
            OK, so jumped SC50 with buffer connections and ground screws removed.
            Got a solid power LED and the LED's on the SC and SS board both lit.
            How can I isolate the problem further to the SD / SU board?
            Connect them one at a time and power on with their interconnecting ribbon cable removed?
            Also, I lack the ability to repair the board(s) myself can someone recommend a shop they have experience with for this? I see multiple ads on Ebay for this service.
            Thanks.
            • ultimatt
              • Apr 2015
              • 29
              Well, Looks like it is an SU problem. There are shorts to ground at both the SU2 and SU3 ribbon connectors.
              If I disconnect SU from both the SC and SD boards and power up will this give me a steady LED and confirm that the SU is the only problem?
              Thanks.
              • tw2005
                • Oct 2011
                • 6458
                Su shorted was going to be my next guess. I have 3 similar model. Shorted sc2 caused a lock out. 2 models 7 blinks both su shorted both onl y 1 buffer ic appeared shorted.
                There are people offering repair of these both on ebay and pts electronics inc.
                Also heatsinked version from higher specced models will work.
                Good luck
                • tw2005
                  • Oct 2011
                  • 6458
                  • ultimatt
                    • Apr 2015
                    • 29
                    "Also heatsinked version from higher specced models will work."
                    Do you happen to have some parts numbers for a heatsinked SU's that will work? If I go that route would I need to replace the SU and SD as a pair?
                    Thanks.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Thanks.
                      I used the AG revision on mine but worth noting on your US S30 model the SU has a cap at C640 which you may want to swap over from your dead bard if you choose.
                      My TV had the AM rev and went with the AG with no issues.
                      • Andre Gilbert
                        by Andre Gilbert
                        11-20-2024, 08:52 PM
                      • nobbnobb1
                        Panasonic TC-P50U50 Powers Off - 8 blinks
                        by nobbnobb1
                        I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                        2x DG302 (Q16051)
                        2x RF2001 (D16041)
                        2x 5.6 ohm SMD resistor
                        1x BD8694 IC
                        I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                        03-21-2023, 08:33 PM
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                      • mmischni
                        Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                        by mmischni
                        Greetings friends,
                        I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                        First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                        09-06-2017, 08:52 PM
                      • dj01fad
                        panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
                        by dj01fad
                        Hello again.
                        I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
                        I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair?
                        10-25-2020, 06:05 PM
