MAGNAVOX 40ME313V/F7 conversion to 220 volts
  • kumag
    • Dec 2013
    • 33
    • philippines
    Hello.. im planning to convert my MAGNAVOX 40ME313V/F7 psu which is rated at 120v.. to 220 volts.. I used to do it by replacing main capacitor.. but only on small appliance. I divided the UF by 2 and multiply the Voltage by 2.. it is in reference with its original main capacitor for 120 v use. Im a little bit hesitant because i have'nt tried that on big appliance. Please help me what to do.. my country is philippines 220 volts.
  • kumag
    • Dec 2013
    • 33
    • philippines
    Re: MAGNAVOX 40ME313V/F7 conversion to 220 volts
    Guys, unfortunately this unit stopped working and i tried to fix it.
    I followed some threads here about philips/magnavox and sylvania.
    And there is now oscillation on the psu circuit but the expected
    secondary readings was 8.7v and 12.5v respectively while it should be 13v and 21v..
    The test was done on this board isolated with the other attachment.
    encircled on the attachment was found defective and replaced..
    Thanks for any help guys..
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • supermattch
      HP 15dy-2021nr wont power on mystery volts
      by supermattch
      Hi everyone.
      I am diagnosing my personal laptop, because it wont power on and no leds light up.
      At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
      Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
      09-23-2025, 12:13 PM
    • MisterAIL
      PS5 digital / No Power / No Beep / Good power supply
      by MisterAIL
      Brought a non functionnal PS5. Apparently only a bad PSU...
      No beep, nothing.
      After some tests i found this :
      - PSU is fine (12 volts stable)
      - 12 volts line is shorted
      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
      - By the way, nothing change. No signal, no power, no beep.
      Mesuring all rails with my workbench psu (12 volts input)
      - 0.00 amp drawing
      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
      03-12-2024, 03:24 PM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
    • tonybig10
      Magnavox MDR515H/F7 And Magnavox MDR537H/F7
      by tonybig10
      Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
      the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
      03-07-2025, 01:03 PM
