Toshiba led tv 32P2305EE won't turn on
  • Nasha
    • Mar 2016
    • 25
    • Riyadh saudi arabia
    Re: Toshiba led tv 32P2305EE won't turn on
    What I need to do next. ?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      maybe a eeprom issue if so im not sure if you can download the firmware, failing that usually it means you need a replacement mainboard but make sure all the board number match even the ones on stickers etc
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        When you switch on now what is the sequence.
        Does the TV come out of standby.
        Does the screen light up very briefly.
        Does the set go back into standby.
        • Nasha
          • Mar 2016
          • 25
          It's only shows a solid red light standby.
          And it's not respond during using remote even manual switch.
          • Nasha
            • Mar 2016
            • 25
            Where I can't download the firmware and how to install it?
            • Diah
              • Feb 2013
              • 6594
              take look deeply on the LED, its Red or Orange red
              • Diah
                • Feb 2013
                • 6594
                go to this side i found, down load yours eeprom dump
                http://aryservis.blogspot.de/2016/01...plasma-tv.html
                • Nasha
                  • Mar 2016
                  • 25
                  #28
                  Diah it's red
                  • Diah
                    • Feb 2013
                    • 6594
                    its eeprom fault on main boards.
                    try to write the dump of it or rebel it again ( some time also with hot air GUN heating it can bring it back ) , if not need replace main boards
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #30
                      Also freezing a eeprom can tempory get it too work some times long enough too read the chip heres a youtube guide by norcal715 https://www.youtube.com/watch?v=Qy8fh-g5DOM
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Its not an Epprom used on these newer Tv's ! its an SPI flash Ic ! Tv's that use Epprom will have a flash stored on the ram bus which rewrites the data to the Epprom Ic every time the Tv is turned on which is more reliable. These newer ones store everything on the SPI flash Ic and load it off there every time the Tv is turned on and off which wares the Ic out fast and the firmware corrupts. I agree with vince try freezing the SPI flash Ic see if it boots then reload fresh firmware.
                        • Diah
                          • Feb 2013
                          • 6594
                          led on stand by mean no cold boot.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #33
                            cheers reece i always get eeprom/spi ics mixed up but its worth a try freezing as you say nothing too loose i guess.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              No worries buddy, sorry if I seemed a little harsh. I was doing the same for a while till Tom strongly corrected me lol
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #35
                                It didnt come across as harsh at all some times it takes a while to sink in my mind,the joys of getting old i guess.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Haha your not that old, right ?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #37
                                    30 years above you lol.
                                      reece 16 + 30 = 46, you are still a young man! I am 62.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #39
                                        Ohh jeez haha didnt think you lot were that old
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          still time too learn then i guess but as you have said with electronics etc were always learning, i just took this up as a hobby late in life as used to enjoy watching my uncle repair crts etc as a child.
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
