Please help lg plasma 60pz550 ua no picture or sound after changing mainboard
  • Joel12
    • Mar 2016
    • 3
    Brand new here so I hope I am following rules correctly.
    I am hoping the experts here can help me with my problem.
    Below is what happened today.
    • My TV is a LG 60 inch plasma 2012
    • Model LG 60PZ550-UA
    • One month ago all my HDMI inputs quit.
    • Video input still worked so I used that.
    • I ordered a new main board part #LG EBT61533403 Main Board for 60PZ550-UA
    • Today I replaced the old main board with the new one and there is no picture or sound.
    • I switched back the old board that I know still worked with video and there is also no picture or sound?
    So now the tv does not work at all!
    I was very careful everything seemed pretty easy but now the TV does not have picture or sound????
    Has anyone ever had this happen or have any idea of what may have happened?
    I really appreciate any input as I am at a loss here. I just hope I did not ruin my tv.
    Thanks,
    Joel
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Please help lg plasma 60pz550 ua no picture or sound after changing mainboard
    It would appear as though perhaps one or more connectors are not seated properly since what is common to both boards would be the re-connections.
    Can you provide photo's?
    • Joel12
      • Mar 2016
      • 3
      Thanks for the fast reply, I will re-check the connections as soon as I get home I will put up some pictures.
      Thanks again,
      Joel
      • cybericius
        • Mar 2016
        • 15
        • Hungary
        I am not sure if your model has the AUTO GEN feature on the Control Board, but you could check if by shorting it and removing the LVDS cable would show anything. This way you could see if the problem is with the Main Board or not.
        • cybericius
          • Mar 2016
          • 15
          • Hungary
          LVDS is the one that connects the Main Board to the Control Board.
          • Diah
            • Feb 2013
            • 6364
            Originally posted by cybericius
            the common mistake by check or replace boards by LG,many things can happen if they don't drain the PSU totally by shorting the main caps at HOT area.
            LG always wrote this as warring at their service manual and its TRUE. as there no drain circuit built at the PSU , they use this to insure fast boot up... hope this not gone of the post owner.
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
